E55 2001
Old Jul 24, 2018 | 07:03 PM
Mike Wilson's Avatar
Sporty e430
E55 2001
I found a 2001 E55 180000 miles seats are fair anything I need to look for when buying one price at 3000 lemon or steal any suggestions
Old Jul 24, 2018 | 08:02 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
The suspension bits will need to be replaced if not already done. Most likely will need engine mounts, shocks and struts, spark plugs, plug wires, coil packs, valve cover gaskets, oil cooler/seals, and crankcase breather hoses. Even if you had to do everything, you are not talking about a ton of money. Afterwards, the car will drive great and you will love how efficient and flexible the engine is in the E55. Tranny may also need replacement soon but you can find low mileage used ones cheap.
Old Jul 25, 2018 | 08:03 AM
Sporty e430
2001 e55
So where talking atleast 2,500 and how soon will i need a tranny wit car having 180,000 miles thought that was kinda light for benzes
Old Jul 25, 2018 | 08:22 AM
e55phil's Avatar
2021 e All Terrain, 2001 e55
I would buy a car with less millage and for more money. In the end you will pay less. However if this is a toy you can have fun with it until it has a expensive problem. Also it not just the money to fix it. It is also your time
Old Jul 25, 2018 | 08:31 AM
Sporty e430
2001 e55
I just was wondering how much did you pay for your E55 my ideal was 150k on mileage this would have 30 more which 180k I also own a E430 sport as of right now I'm at 208k car shifts like butter
Old Jul 25, 2018 | 08:35 AM
e55phil's Avatar
I have seen cars under 100,000 miles and under 10,000 dollars. I paid 20K for one with 50,000 miles and 8000 die one with 130,000 miles
Old Jul 25, 2018 | 08:45 AM
Sporty e430
2001 e55
just be smart after I buying a E55 2001 for $3,000 it is best to go ahead and go through spark plugs engine bay and already buy a used E55 transmission with a hundred k on it will I be fine to do so also go through my suspension not to mention the E55 has 6 owners I need help my fellow Benz owners
Old Jul 25, 2018 | 08:48 AM
Sporty e430
2001 e55
I have made my E430 sport a daily driver I have plans to have my E55 do the same as well I would only know if a E55 is a fun weekend car by a guy who has 1 in front of his house I have made 430 sport a daily driver could I do the same for the E55
Old Jul 25, 2018 | 11:48 AM
NAFT1's Avatar
1999 E55 AMG, 2004 Big Turbo A4; 2005 C240 Wagon 4matic; 2003 G500; 2013 Sprinter 172
It really depends on how the car has been maintained. If you can appraise what is good and bad and don't mind working on it to get it into the condition that you want it, then go for it. I have known fantastic E55s at that milage and I've seen some crap buckets that I wouldn't take for free.
Old Jul 25, 2018 | 12:43 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Get a PPI done. If it checks out or you're ok with doing the work then buy the car. We can't tell you if it's a good car sight unseen. It might be a piece of **** that's not worth buying or an ok deal at that price.
Old Jul 26, 2018 | 04:16 PM
fabbrisd1's Avatar
A gaggle of MB's
Frankly - at 180K miles a E55 can still be running strong.
The key component here is the tranny - if the tranny has had proper service - and fresh tranny adapter plug - then a well maintained tranny can go out well past 250K. If the tranny has not had legitimate service/maintenance - then at/about 175K/180K is about the time the tranny can turn to toast.
The other thing to look/avoid is any cooling-system/tranny cross-contamination which can occur with failing coolant/tranny-fluid lines.
On the maintenance side - you have a rock solid V8 - pending any exceptional problems - of note front brake rotors for a E55 are about $400 - as compared to like $100 for a E320/E430.
The
Old Jul 29, 2018 | 09:58 PM
trinitony's Avatar
E55 C43 993C2S
My daily driver is now at 190k miles and still running strong.
