Shes good, now need help with lights.
Old Aug 12, 2018 | 12:34 AM
SeanDaugherty's Avatar
2002 E55
Since shes now running, I found the bulbs are dead, who makes a good aftermarket projector headlight for hid?
Old Aug 12, 2018 | 11:28 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
What car do you own?
Old Aug 12, 2018 | 01:36 PM
2002 E55
2002 Mercedes E55 with factory HID
Old Aug 12, 2018 | 02:31 PM
AZN Optics's Avatar
SPONSOR/MBworld Guru
Are you looking to replace your entire housing, retrofit new projectors, or just replace the stock D2S HID bulbs with newer bulbs?
Old Aug 12, 2018 | 02:36 PM
2002 E55
I want to upgrade the housing to projectors while keep the hids.
Old Aug 12, 2018 | 03:10 PM
AZN Optics's Avatar
Morimoto Mini Stage 3
Old Aug 12, 2018 | 03:39 PM
2002 E55
Originally Posted by AZN Optics
those wouldn't work with the factory glass diffuser and I'm not qualified to install that.
Old Aug 12, 2018 | 04:54 PM
AZN Optics's Avatar
Factory glass diffuser? You mean the refracted outer lens?
Old Aug 12, 2018 | 05:42 PM
Sgtmac's Avatar
2010 c300 sport 4matic
Low beams out
I have a 2010 C300 with hid lights. The low beams are out but the high beams are on. Do both high and low lights work off the same ballast?
Old Aug 12, 2018 | 10:49 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Make a new thread in the correct section. Don't try to piggy back off someone else's.
Old Aug 13, 2018 | 02:21 AM
2002 E55
I guess same thing. It has the factory d2r whatever bulbs and ballast but there is no projector just the glass that uses a diffuser style to it.
Old Aug 13, 2018 | 03:10 AM
AZN Optics's Avatar
Yeah, those refracted lens are crap. Really comes down to your budget situation... You could just get better HID bulbs and call it a wrap... Maybe polish the lens to remove any hazing. Otherwise source some depo or hella aftermarket headlight replacement that have the cleae lens with projectors. Try to get ones that don't package an HID kit or bulbs as those will be crap that'll probably fail in a few months. Better to pair with a quality bulb set.
Old Aug 13, 2018 | 12:20 PM
illest's Avatar
w210 AMG or S213
If you want the best light output get some depo projector headlights form ebay, swap out the projectors for something better (the ones they come with are trash) and put in a good HID kit. There is a DIY here . Your current HIDs are not designed to work in projector housings.
