Coupe Vibration Mercedes w210 E55 AMG.
i have changed to new micheling tyres all around.
Changed the parts on the driveshaft, rubberparts dont know the name.
any tips will be appreciated!
Good luck.
If you're not getting a rattling or clicking or thumping noise coming from the same area when going over bumps, then it's 99% likely a wheel bearing if it's not your tire or alignment. Swap the front tires (rims and all) to the opposite side and see if the problem persists. It takes 10 minutes. If it does, you can eliminate the bad rim/tire/balance. If it changes to the other side, it's a rim, tire, or balance issue.
Another note is that you said the sound is there while going straight and stops when turning/curving left...... Does the sound increase when turning or curving right? If so, definite wheel bearing.
