Torque Limiter?
Old Sep 19, 2018 | 12:29 AM
SeanDaugherty's Avatar
2002 E55
Torque Limiter?
So when I punch on the gas it takes off then pops into neutral. Fluids perfect, shifts normally otherwise as long as I don't punch on it. Someone said it's probley my torque limiter kicking in. Because as soon as it goes to neutral, if you park and go back to drive, no issues. I did get a 2500 code and cleared it, reset the trans adaption via scantool. Still does it, so what is the torque limiter, where is it located and can I adjust my programming to turn it up?
If this doesn't work, who makes the best trans for our cars?
Old Sep 19, 2018 | 11:39 AM
2002 E55
UPDATE: If I turn traction control off, it does not have this issue. It will shift from gear to gear no problem even under heavy load.
Old Sep 19, 2018 | 11:45 PM
fabbrisd1's Avatar
A gaggle of MB's
Sounds like you might need 2 new rear tires - start by checking both rear tires 1st - for same size and brand - then check for equal tire pressure on both sides - then ask yourself "will I be better off with two new rears tires"..
Old Sep 20, 2018 | 12:00 AM
2002 E55
they are the same size, the dude before me vetoed this car and went to 20" wheels. 275 /30 r20 in the rear, 2r5 35 r 20 in the front. Keeping my eye out for a set of OEM monoblocks.
Old Sep 21, 2018 | 02:34 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Have you searched torque limiter on the forums? There's lots of threads about this stuff.
