Advice in stance
Old Oct 31, 2018 | 10:11 PM
noud's Avatar
99 E55, 00 S500, 01 CLK55, 01 E320, 04 E320
Talking Advice in stance
My oldie 1999 E55 is on 18 inch. I dont know but its kinda sitting high. If its normal what do you guys will fit better, getting spacers or shorter springs?
Old Oct 31, 2018 | 10:13 PM
Bahnstormer's Avatar
2010 E63 AMG, 2003 E500
Something ain't right.
Stock suspension?
Old Oct 31, 2018 | 10:14 PM
noud's Avatar
yeah, everything looks stock. I bought it like this
Old Nov 1, 2018 | 09:40 PM
AndreNY's Avatar
couple of Benzos
that is 1000% not stock, it looks like it has E300D springs with the #4 pad
Old Nov 1, 2018 | 09:44 PM
noud's Avatar
hmm, that does not sound right. i have to dig into this
Can anyone advice on what spring color codes are for our 99 e55?
Old Nov 1, 2018 | 09:48 PM
noud's Avatar
Last edited by noud; Nov 1, 2018 at 09:49 PM. Reason: cant delete this double post, sorry
Old Nov 2, 2018 | 10:25 AM
illest's Avatar
w210 AMG or S213
Looks like the height of my old 4-matic. Get smaller spring pads.
Old Nov 2, 2018 | 10:29 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
See attached for spring information for a 1999 E55.
Old Nov 2, 2018 | 10:34 AM
NAFT1's Avatar
1999 E55 AMG, 2004 Big Turbo A4; 2005 C240 Wagon 4matic; 2003 G500; 2013 Sprinter 172
I believe that my rears have two yellow and two one white marks on the 4th coil. Not sure if the fronts are the same or different but I'll try to look. Mine below is 100% factory original U.S.-spec suspension.
Correct ride factory ride height on 1999 E55
Old Nov 2, 2018 | 10:51 AM
NAFT1's Avatar
Corrections: 3 white + 1 yellow on front; 2 yellow + 1 white on rears. Better pics or how it should look. 275/35/18 rear on Mono II.
1999 E55 Fender Gap
1999 E55 RearCoil
1999 E55 Front Coil
Old Nov 9, 2018 | 09:22 PM
noud's Avatar
Thank for replies guys!
Based on the pictures NAFT1 posted, then US spec E55 is really sits high rather than 2001 facelifted or EU. On weekend ill crawl under my car to see color codes, and even ifts end up being corect springs Ill cut one spin from all 4 to lower it down it really feels high, those lifting center of gravity.
Old Nov 28, 2018 | 04:29 PM
noud's Avatar
Yup, springs are original with correct markings. I guess 99 E55 supposed to seat high, but I dont like it. Will cut them and post some updates.
Old Nov 28, 2018 | 05:09 PM
There's absolutely no way AMG shipped that E55 out their doors sitting that high.
Something's not right.
Old Nov 28, 2018 | 05:24 PM
noud's Avatar
if not springs, what else?
Old Nov 28, 2018 | 05:30 PM
Spring pads?
Old Nov 28, 2018 | 05:32 PM
noud's Avatar
I can look into that but knowing the history of this car I doubt that someone ever replaced them or knew about their existence
Old Nov 28, 2018 | 05:59 PM
Stock 1999 E55 for comparison.
https://driving.ca/mercedes-benz/e-c...des-benz-e55-2
Old Nov 28, 2018 | 06:17 PM
noud's Avatar
on picture is facelifted 00-01 E55, not 99, but even on picture its obvious that car sits high. So I guess being high is not only 99 related.
PS. It was a good read, but being strong mercedes fan I drove my friend's 2002 M5 at that thing is monstrous compared to our e55, and almost similar torque wont help much.
Old Nov 28, 2018 | 06:31 PM
Did you click the link noud?
It's a review of the 1999 E55 and it has that exact same picture.
Old Nov 28, 2018 | 08:01 PM
noud's Avatar
I did, and picture posted is NOT 1999 E55, it is facelifted post 2000 model. Look at bumper, side mirrors, hood
Old Nov 30, 2018 | 12:18 PM
NAFT1's Avatar
My car is a 1999, pictured above, and it sits a bit higher than the European models which are usually used for the press photos. There is nowhere near the wheel arch gap that the OP has. What size/offset wheels & tires are currently on the car? Maybe that's the problem.
Old Dec 1, 2018 | 06:40 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Another reference pic. My old 2001 E55 when it was on the stock springs and wheels.
Old Dec 1, 2018 | 07:04 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
The OP's E55 looks like it's ready to go rock crawling... Get some vogtlands, new bilsteins, #4 spring pads and call it a day
Old Dec 3, 2018 | 09:46 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
It could be the shock absorbers. I've read of a couple of cases where the owner installed replacement shock absorbers and the car was suddenly 2" higher.
