06 CLS 55 Wheel Fitment?
Old Jan 14, 2020 | 06:41 PM
MassE55's Avatar
2001 e55 AMG
I have an opportunity to buy a set of 19" 2006 CLS55 AMG wheels(no tires) for short money. I searched and couldn't find whether they will actually fit on my w210 e55. Seems like a few people tried but failed others seemed to make it work. Any insight would be appreciated.
Old Jan 14, 2020 | 07:00 PM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
What are the widths and offsets? Rear may fit but the front I doubt it. If the wheel/tire goes inward more than a 18x8 et31 it will rub on the suspension nut above the front tire.
Old Jan 14, 2020 | 07:21 PM
MassE55's Avatar
2001 e55 AMG
The specs of the wheels:
8.5JX19, offset 28 Front
9.5JX19, offset 25 Rear
Old Jan 15, 2020 | 09:09 AM
MattCordell's Avatar
C43 AMG with a tune up
I have seen these on w202 C43, check youtube videos.
Looks very nice on the C43
Old Jan 15, 2020 | 10:00 AM
illest's Avatar
w210 AMG or S213
They will fit. You might need spacers
Old Jan 15, 2020 | 01:21 PM
MassE55's Avatar
2001 e55 AMG
Thanks Gentlemen. Going to see how they are tomorrow. Here was the video I saw that made me think of it.
Old Jan 15, 2020 | 04:33 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Front should be fine. You may have to run a smaller tire in the back.
Old Jan 16, 2020 | 10:32 AM
E55 KEV's Avatar
Veteran: Air Force
Use this offset calculator - https://www.1010tires.com/Tools/Whee...et-Calculator#
Front tire:
Inner - 3mm LESS
Outer - EXTEND an extra 9mm
Tire may rub on the upper suspension bolt. Also that video may not be US. Non US W210 E55's use a 235 tire up front and 265 tire in rear from factory.
Old Jan 16, 2020 | 01:48 PM
MassE55's Avatar
2001 e55 AMG
Front tire:
Inner - 3mm LESS
So if run a 5mm spacer up front I'll be 14mm extended from stock setup but would clear the upper suspension bolt, correct? How much you think that would stick out past the fender and by running smaller tires would effect the ride? I'm scared to do it given I live in Massachusetts and the roads suck up here. Might just go back to the drawing board and stay stock wheels and do the Ksport or PB Brake coilover instead. My stance now looks like a 4x4 but the euro springs are stupid money and I would probably replace the shocks at the same time. So coilovers seemed like the best option given the price point for conventional suspension and I'll have the ability to raise and lower to find the right balance.
Thanks for the help
Old Jan 16, 2020 | 02:38 PM
E55 KEV's Avatar
Veteran: Air Force
Thanks for the help
It's a big decision. That 245 tire and 8"/et31 up front is maxed out (IMO) and may rub on fender with a spacer. It may be some trial and error to fit a correct setup. Personally, I would never use a spacer. I've seen the bolts snap under load.
Old Jan 16, 2020 | 02:47 PM
MassE55's Avatar
2001 e55 AMG
May not be worth the hassle. I like the Mono blocks just hate my stance so maybe I'll just stick to suspension upgrades and not getting bigger wheels. They don't make it easy to upgrade anything on these cars. Spoiled american problems I guess 🤣🤣🤣. I appreciate the help KEV
Old Jun 15, 2020 | 11:57 PM
MassE55's Avatar
2001 e55 AMG
Just as follow up, the CLS55 wheels fit perfectly with custom lugs from Otis. As much as I love the monos, these wheels make the car look more relevant. Thanks again for all the help everyone.
Old Jun 17, 2020 | 09:33 AM
illest's Avatar
w210 AMG or S213
Looks good.
Old Jul 30, 2020 | 11:25 PM
MassE55's Avatar
2001 e55 AMG
Originally Posted by illest
Looks good.
Thanks bud. Super happy with the final look.
Old Jul 31, 2020 | 11:36 AM
eurochargedw210's Avatar
w210 E55
OTIS is the man! I buy all my lug bolts from him.
Old Jul 31, 2020 | 07:32 PM
MassE55's Avatar
2001 e55 AMG
Awesome guy. Knows his ****.
