Multi contour seats
Old Jul 21, 2020 | 09:54 AM
Tom Ulsas's Avatar
2000 E55 AMG
Multi contour seats
Has anyone removed the controllers on the seat? I got the front clip but can’t seem to get the back off. Any idea how it is to be removed? Thanks.
Old Jul 21, 2020 | 03:10 PM
Jp3dflyr's Avatar
01 W210 E55 AMG
Yeah I replaced both of mine because they were leaking. Here's a few pics from the bottom. The other side slides up but it is tight. I think I used a plastic pry tool and took my time and it slid straight up. Be careful with the air hoses underneath, they can be brittle.
Old Jul 21, 2020 | 09:40 PM
Tom Ulsas's Avatar
2000 E55 AMG
Thanks. Got them off. I can hear the pump running and feel the air at the controls so I don’t think that is the problem with the seats deflating after 30 seconds. I did put a little grease in each inlet in the switch just in case there was a leak there. Any idea if that means there’s a seat bladder gone bad? Thanks for the help
Old Jul 22, 2020 | 02:33 AM
desired_speeds's Avatar
2007 SL55 AMG
If it deflates after 30 seconds it means there is a leak that's causing the pump to overrun and it shuts it down to prevent the pump from burning out. A good method to determine where the leak is coming from is to use a small hand pump and test each individual bladder to see which one isn't holding pressure.
Old Jul 28, 2020 | 10:27 AM
Tom Ulsas's Avatar
2000 E55 AMG
so all bladders are holding air based on pump test. Could it be the actual switch on the seat?
