New 80mm throttle body mod
Old Nov 27, 2020 | 09:53 PM
eurochargedw210's Avatar
w210 E55
In the works. I will let everyone know once it’s completed and dyno tested. May sell it as a kit.
Old Nov 28, 2020 | 11:03 AM
6spd's Avatar
00 ML55, 00' E55, 03' CLK55
Good luck, this will be a good mod for these engines....Was just working on this. I bored my intake manifold, used an 82mm adapter and tb. Only to find out my old me 2.0 wouldn't support the new style bosch connectors. ME2.0 processes signals different. I even wired in a newer style connector to no avail. . Is this a new TB or a modified 74mm?
Old Nov 28, 2020 | 11:18 AM
w210 E55
Oh yea Me2.0 sucks, that’s why I sold my 2000 and bought a 2002.I feel 82 it to big for these cars. This is an 80mm throttle body. Spent about 5 hours yesterday researching, throttle bodys, spacers, and adapters. Gonna find out this morning when the parts get to the shop if it’s going to work or not.
Old Nov 28, 2020 | 11:35 AM
6spd's Avatar
Nice.....82mm is only a 9% increase over stock, so I figured between my other mods it would be perfect. Was looking forward to the throttle response increase but the only way for us me2.0 guys is to go custom. Considered boring my stock but its low priority at this point. I'm married to my car so ill keep chipping away at different mods to do. Doing everything I can thats not forced induction. Lol I love being able to drive my car hard all the time with no reliability issues. Side note. My car started and idled with the 82mm but would go crazy when I gave it gas. You just need the wiring schematics of me 2.8 vs. Whatever system the 80mm tb is off of. Is that a sl55?
Old Nov 28, 2020 | 12:01 PM
v8sonly's Avatar
2002 E55, 2003 ML500
:LIKE:
I do wonder how much power potential is hiding in these NA 5.4s. I think it's a lot more than people realize, even though the default answer for years has been to slap a blower on it...lotta basic hot-rodding tricks (like this) overlooked in-between. GOOD LUCK!
Old Nov 28, 2020 | 12:25 PM
w210 E55
This is a dodge throttle body, from a 5.7 and 6.4. Waiting on the v6 74mm throttle body to make sure the bolt pattern is the same or close enough.
The 07/08 SL55s came with the 80, they are 1600$ list and you can’t find them use. I believe well over 1000$ even at cost. But we have used BBK hellcat throttle bodies before on 113k cars. Just need a wiring adapter.
Old Nov 28, 2020 | 12:54 PM
6spd's Avatar
Damn $1600?! Sheesh ok cool. Keep us posted. I always felt this was a missing link for NA M113s. The dodge approach could be a cool alternative.
Old Nov 28, 2020 | 03:46 PM
cm60k's Avatar
I tried to do this nice TB upgrade with several arrogance tuning vendors..,,
but most of them preferred to play ignorance games..!!
-;-ZAYED-;-
Old Dec 1, 2020 | 09:44 AM
w210 E55
-;-ZAYED-;-
Which one did you try to use?
Old Dec 1, 2020 | 12:47 PM
cm60k's Avatar
Tried many of them due 4>>6 back years..!,
some of them says; we working with new models only..!!!!,,
ahhhhh, you know;
want to kiss your ears, just hold the mirror..
-;-ZAYED-;-
Old Dec 1, 2020 | 01:30 PM
w210 E55
ahhhhh, you know;
-;-ZAYED-;-
Well this is the same as the BBK 90mm we used on our shop car. you just need the harness and rewire it. It shouldnt require any tuning. I also have an adjustable FPR so i can turn it up if it leans it out.
Old Dec 3, 2020 | 02:15 PM
w210 E55
80mm throttle body going on my e55. Should have it on this evening or tomorrow. Hopefully dynoed this weekend also!
Old Dec 3, 2020 | 03:15 PM
cm60k's Avatar
Looks awesome, you Rock bro..
-;-ZAYED-;-
Old Dec 3, 2020 | 09:11 PM
6spd's Avatar
This is great! Did you get a larger MAF housing as well?
Old Dec 3, 2020 | 09:32 PM
w210 E55
No, I may try a m273 if it comes down to it. But I am just going to try this first. Will the minimal grinding to the elbow it will slide over, and I will seal it with just right stuff sealant.
Old Dec 3, 2020 | 09:55 PM
6spd's Avatar
yea i did the same with the 82mm. I was going to use a
D2 audi S4 intake elbow as a friend of mine did that. Also they use a larger 82 MAF housing as well. So you could utilize the larger intake tubing to match. That introduces the issue of accurate MAF readings though.
Old Dec 3, 2020 | 10:56 PM
w210 E55
I mean, I already have 3.5in take tubing. I think for now the stock mass air flow will be ok. I will eventually get an 113k ME to run ig off MAP not get ride of the MAF
Old Dec 21, 2020 | 02:20 PM
Boldkitty's Avatar
02 E55. 14 Tiguan
Do you know the part number for the 07/08 SL55 TB?
Old Dec 21, 2020 | 02:45 PM
w210 E55
I can look it up, they are 1600$ list price and not even sure if the dealer has any, I also know they are extremely hard to find used.
Why do you need one of these?
Old Dec 21, 2020 | 02:49 PM
Boldkitty's Avatar
02 E55. 14 Tiguan
Hi...I was just following along with your update. I thought maybe you “knew” the number. It seems ebay has dozens of 07/08 SL55 TBs so I assume they are the wrong ones.
Old Dec 21, 2020 | 02:57 PM
w210 E55
Yea most of them are the 74mm just like e55 113k cars. I haven’t looked into it but I have seen a few people try m273 82mm throttle bodies, but not sure how it’s working for them. This is a 5.7/6.1 hemi throttle body from the earlier generation cars. Same plug as the 90mm bbk people are using on 113k cars.
I don’t see any point in trying to find a sl55 80mm TB. I am still waiting on a 90° silicone reducer elbow. Hopefully going to dyno the car later this week.
Old Dec 21, 2020 | 02:58 PM
w210 E55
Old Dec 21, 2020 | 03:02 PM
Boldkitty's Avatar
02 E55. 14 Tiguan
Yea...when i use number 1131400104 all those tb disappear.
Old Dec 22, 2020 | 03:23 AM
cm60k's Avatar
Yeah sure, 06-08 "SL55 AMG", with Engine # "M113.995", is the only "M113K", that use (80mm) TB,
* (80mm) TB, with harness, #: "113 141 05 25"
* (80mm) TB, without harness, #: "113 140 01 04"
i would think 98-02 "W215 CL600" & "W220 S600" with "M137", also uses (80mm) TB,,
harness pins & connector are the same with "M113K", but not that sure if need swapping the wires..?!?!?
-;-ZAYED-;-
Old Dec 22, 2020 | 01:12 PM
Boldkitty's Avatar
02 E55. 14 Tiguan
Interesting...I enter the part number 113 141 05 25 on ebay and there were 164 results but all but 1 with a wrong part number (113 141 01 25). They were 50-75 dollars and the 1 with the correct number was 1100 dollars. Ebay is really crappy.
