Multiple front crank seals?
Old Aug 7, 2021 | 01:12 PM
Traumamatic's Avatar
01 E55
The dampener pulley and front crank seal were just replaced on my car. The mechanic noted that there were two seals in place, which he replaced with one. On the way home, I started significantly leaking oil from the front crank seal area. Was some kind of spacer potentially left out? Is the two seal approach something that is commonly taken?
Old Apr 22, 2023 | 03:49 PM
pdf6666@aol.cxo's Avatar
2015 mercedes gl350
Got it off with my milwaukee gun. Just had to take out the electric fan..
Old Apr 22, 2023 | 03:53 PM
2015 mercedes gl350
Old pulley failed. I guess it would be good preventive maintenance to change. It's expensive, glad it happened at the house. I have 110k on it. I know on heavy duty trucks recommended changing damper at 400k-500k
Old Apr 22, 2023 | 08:20 PM
6spd's Avatar
00 ML55, 00' E55, 03' CLK55
What kind of failure?
Old Apr 22, 2023 | 08:58 PM
2015 mercedes gl350
i posted under the wrong one. check the diesel forum
Old Apr 22, 2023 | 09:58 PM
6spd's Avatar
Copy that!
