Upgraded suspension question?
2003 Corvette Z06, 1999 E55 AMG
I need to replace my front springs. I am wondering if there is an aftermarket suspension or coil overs that I can put on all 4 corners that lowers the car a little bit but keeps a nice comfortable ride? Any advice would be helpful. Thanks!
'99 and '05 E55 AMG
Have you considered the thinnest spring perch spacers with stock springs or equivalent springs? You can always contact Eibach with spring height, diameter, and rate (or usage) and see what they recommend. Do not go too low.
Personally, I find the rebound damping on my Bilstein shocks (even with stock springs) is far too low. Looking at moving to another shock absorber; preferably adjustable. Possibly Konis but I have not made the time to research if available for the W210.
Also, the W210 does not use coil overs; the spring perches are separate from the shocks. Not trying to be a grammer ****; just trying to make it easier for you find what you need.
EDIT: FWIW, my '99 E55 is a Canadian car that somehow migrated down to South Texas and never returned North. The "kilometers" reading in the odometer really messed with my fuel mileage calculations for the first week or so that I owned it. I was thinking "35 miles per gallon?" when it was 35 kilometers per gallon.
