Loose Steering + Steering Vibration at 45-50 MPH
Old Sep 18, 2024 | 09:24 AM
w210e55T's Avatar
01 E55 Wagon, 00 Renault Clio 172, 03 4Runner V8
Hey everyone,
I've got a 2000 E55 Wagon, approx. 101k kms.
I've done a bunch of reading, and this post was super helpful:
https://mbworld.org/forums/w210-amg/...iles-hour.html
I've got both A) the vibration at 40-45 MPH, when the car is cold it's most pronounced, and b) I've got really loose / tramline steering (noticeable above 30-40MPH).
I'm not sure if these are related, or I'm just lucky and have 2 separate issues at the same time.
I'm going to get the rear subframe mounts replaced (haven't checked yet but guessing its worth a shot), and new rear tires. Is there anything else that I should get done at the same time, in case the vibration isn't this issue (and to save on labour and future headaches)? I've seen that it could also be a rear propeller shaft/driveshaft issue as well, so I'll look at that too.
I've already replaced:
  • Front upper and lower control arms
  • Front ball joints
  • Front tie rods
  • Front dampers (bilsteins)
  • Front sway bars and links and bushes
  • New front tires
  • Engine and transmission mounts seem to be okay and replaced before I got it
Old Sep 18, 2024 | 09:43 AM
w210e55T's Avatar
This is also a great thread:
https://mbworld.org/forums/w210-amg/...-bushings.html
Doing some research, the 4 subframe mounts/bushes for e55s have these part numbers:
2103507408
2103507508
But it looks like the second part is discontinued: https://www.fcpeuro.com/products/mer...507508#fitment
Anyone found them recently, or know the difference between these and the regular w210 parts?
Old Oct 29, 2024 | 05:17 PM
Bigbash's Avatar
E55 AMG, C63s T, SLK55, S55, ML63, E30 M3, E36 M3, E34 540 6sp
Not a problem with the Servotronic? It is supposed to adjust the sensitivity of steering input depending on speed.
I think E55 rear bushings have more solid rubber, to take that extra torque compared to rest of the W210s. I actually recently ordered new bushings for my rear subframe and my delar said 2103507508 (which was a kit for both sides) is now replaced with:2x A 210 351 12 42 – bushings around 90 USD/piece
2x N 009021 013203 – washers 2 USD/piece
2x A 202 990 05 04 – bolts 7 USD/piece
Old Oct 30, 2024 | 09:01 AM
mbwillgrubs's Avatar
2013 CL 63, 2002 E 55, 04 Jaguar XJ8, 66 Jaguar XKE
Tires? My E55 with worn tires will tramline pretty bad. Also, some performance tires will take a set when cold and take a while to work out the set. My current tires will do that if they have been setting for a day or more. Drive for a while and all is well.
Old Oct 30, 2024 | 01:24 PM
broham's Avatar
A4
Watching this thread as well...mine has that steering wobble at exactly 45mph as well..two shops could not find the culprit. Now, I do have a bent rear wheel that I was just advised of. But i dont think that would be causing this issue that strongly in steering wheel? Maybe Im wrong.
Old Mar 17, 2025 | 04:05 PM
w210e55T's Avatar
Just coming back here with my follow-up. Shop replaced the rear tires, and that helped a bit, but the vibration is still there, and the light steering is still there.
I've got the rear mounts to do, and will see if that helps.
I'm also looking into the servotronic to see if that's the issue with the light steering.
