can you still smoke the tires off the line?
old man and his car as your name is, says it all.
GFY
As far as plugs go, pull one and take a look at it. If you change plugs and wires yourself, allocate two and a half hours and be sure to have the MB spark plug boot tool and the swivel spark plug socket. Use compressed air to blow out the spark plug wells to remove dirt and sand and use Bosch plugs from a reliable dealer. You'll need to swing the coil packs out of the way; be sure to check the connectors and wires for breaks in the insulation. No Ebay or Amazon plugs and no "special sales price" plugs! Counterfeit plugs get mixed with the OEM supplier plugs. I got caught by that one time; never again. I was pulling and replacing plugs after ~26,000 miles and the counterfeit plugs all opened up spark gap from the installed 0.039" to 0.060" or greater after only ~26,000 miles.
FWIW, my Canadian-spec '99 E55 has over 288,000 kilometers on it, still has impressive power, and is my "go-to" car for 500-mile road trips. Don't forget to check your air filters as well; that's another one that got me once. PITA to replace (who the f**k uses that many screws on a filter box instead of snap clips?) but filters are not that expensive.
Ignore the curmudgeons who bring no value-added to the conversation. The user named "Plutoe" is a curmudgeon but he brings decades of MB technician experience to the conversation so I make it a point to read any post which he makes.
Not exactly a litmus test for engine issues....the good ol burn out....
Enjoy the rest of your week and thanks again.
Also, if the tires are slipping more than about 10-15 per cent, one is not accelerating optimally. So, burnouts expensive and not conducive to fast lap times...of course, too much grip busts axles, differential gears (done that), transmission (yep, done that), clutches (sigh ..yep), driveshafts (Le big sigh...yep. At 2:00 AM XMAS morning miles from home)...
I'll go finish my bottle of very nice red wine now...
All of bbirdwell's comments are accurate. You might also take a close look at cam cover gasket leakage. I ended up replacing those after the plug change due to oil leakage on the passenger side rear.
A "reset" of the throttle adaptation might help with the throttle response and the feeling of power. Mine can feel pretty sedate until I drive it "peppy" for a while. Good luck.
That specifically depends on the goals of the car. These are effectively "Hot" Family Sedans. They have system after system to protect you, from you. Unfortunately, as we go forward in the Nanny State cars are getting less and less fun, more and more dependent on gizmo's to get us from A to B (and creating generations of dangerous drivers).
While you are not a fan of the answer, the reality is that an E55 is not, never was a "Burn Out" car - certainly not with out some serious modifications to "dumb it down". Possibly there is a WS6 or old school Mustang that fits the bill? Not too long ago there was a killer El Camino on BAT.
The car is what it is....you need to accept that.
My newer E63S and GLS do not seem to know they exist. Only recently with the W213 is the "Goof Mode" (to quote a video from YouTube) created to allow for real drifting. In the RWD E55 and E63 it tries to solve the problem you as a driver do not have. 2014 and newer (with 4matic) it is a moot point.
