Ordered a set of 840R: tire monitoring?
Old Mar 30, 2005 | 02:16 PM
JAY55's Avatar
///E63V10 ///F80CS ///Can-Am X3 XRS
finally decided and ordered a set of black 840R 20's. I have tire pressure monitoring and don't plan to put the sensors on the new wheels, will there be any warning light, beeping, etc.? Thanks in advance!
Old Mar 30, 2005 | 02:25 PM
vrus's Avatar
2003 E55 AMG
As far as I know the TPS sensors WONT work on the 840R. They are a reverse-lip design and thus the sensor will not fit in the valve stem.
The only way I know to make TPS sensors work is to cut the valve stem off the sensor and epoxy & band-clamp the sensor to the center of the wheel.
I've done this on a couple of past cars of mine and it works fine.
Old Mar 30, 2005 | 04:01 PM
Harris's Avatar
Yes, you will have a warning light from the dash.
The dealer should have told you that......no?
Old Mar 30, 2005 | 04:09 PM
Karsa's Avatar
I think you will get warning.
Congrats for the HRE wheels. Pls post some pics when you had installed them.
Btw, pls check your PM and let me know...
Old Mar 30, 2005 | 04:50 PM
JAY55's Avatar
I just called the dealer trying to get an extra set of sensors, freakin' $288.00.
