Is Wetterauer Chip - any good???
Old 04-16-2005, 04:02 PM
E55 RUSS's Avatar
E55K
I wonder if anyone here had any experince with Chip tuning their e55's with Wetterrauer...
Sounds good!!!
displacement: 5439 ccm
compression ratio: 9.0:1
power: 350 kW/476 hp at 6100 rpm 390 kW/530 hp at 5600 rpm
torque: 700 Nm at 2650 rpm 850 Nm at 2800 rpm
top speed: 250 km/h 300 km/h
remark: removing the speed governor, otimised for premium fuel
price: nett tax included
power advancement from 350 kW/476 hp to 390 kW/530 hp incl. installation
1637.07 € 1899.00 €
Is Russia this chip costs only $550
Old 04-16-2005, 09:34 PM
tommaey's Avatar
2012 C63 Coupe Iridium Silver
I don't think power and torque gains that large are physically possible with just an aftermarket chip. If this chip tuner can do it, why didn't AMG?
It looks like that power increase works in conjunction with performance parts such as pulleys headers etc...
Old 04-17-2005, 03:21 AM
E55 RUSS's Avatar
E55K
But Wetterauer is a reputable German Chip Tuner!!!
Most of Mercs tuner gives 10-15 HP with chip for E55...
Anyone else
Old 04-17-2005, 09:49 AM
tommaey's Avatar
Sure they are reputable, but how is it physically possible to get that much more power out of an engine with an electronic chip?! Think about it. You can only fiddle with fuel:air ratios to a small extent... to burn more fuel and thus produce more power, you need more air... And a chip can't force more a air into the engine... Only upgraded pulleys can... Most chip tuners can only get 10 - 15hp because thats the most that is possible.
If this chip tuner is reputable, what is AMG? Don't you think AMG know how to tune their engines?
These figures are either a misprint or bullsh**
Old 04-17-2005, 03:35 PM
E55 RUSS's Avatar
E55K
Dont know what is that..BS or NOT...
If I wont get stage 2 from Kleemans will try that and do a Dyno...
Also I found out of MKB site thier stage 1 is 540 Hp with only a chip and cold air intake...
And SL has 500 hp when chipped by Kleemans or other has 515...That means E55 could be chipped to 515....
Anyways stage 1 SL has 540 HP and E55 520...everything is the same...may be less boost or better exhausts...
Quick Reply: Is Wetterauer Chip - any good???
