I think my car is permanently stuck in Dyno mode.
AMG 55, 335i, Mini Cooper S
Every since I had my car dyno'd my ESP doesn't work. The only time the ESP works is if I don't step on the brake. One the brake pedal is pressed the lights come on. When I start the car the BAS and ESP lights come up. My car will also shift into Drive without your foot on the brake pedal. Is there a way to reset this. I have already replaced my BRAKE Switch under the pedal. It did not help.
Thank you
Thank you
AMG
Thank you
Thank you
[QUOTE=Marky]How did you get your car into dyno mode? Did you just pull the ESP fuse?[/QUOTE
The car was dyno'd by Powerchip but they have looked at it twice and have had no luck repairing it. I'm not sure what they did to to put it in dyno mode. The ESP triangle will light up as long as I don't step on the brake pedal.
Originally Posted by E55JAY
Sorry about your problem...what numbers did you produce on the dyno?
Originally Posted by Vadim @ evosport
Try disconnecting the battery. Check the fuses for BAS/ESP.
You most likely paid them to work on your car so you should not bear the expense and headache of having and fixing a car that has a malfunction.
Do not entertain any "coincidental" excuses.
Originally Posted by thearle
Then it is your legal right to leave the car with them for them to fix it (at their expense) and it is their obligation to give you a loaner car of equal value (at their expense) until the problem is fixed.
