More rumors about new N/A motor hp.....
the frigen mclaren f1 makes 627 NA hp with a 6l v12 and you think a mb NA v8 can make it.
BTW iv heard turner motorsports F1 and let me tell you its sound like a fighter jet.
Not even bmw can make that much power from a v8 and even the new z06 with its 7l v8 is only putting out 500 so please shut up.
Now ill ask you once more please explain to me on how MB is going to get 600 plus hp out of a v8 without using 13.1 compression or even higher.
You need more cyl and very high revs to make that much hp(600 hp)NA
Im not talking about 100hp/l im talking about making 600 hp with a v8.
bmw had to make the v10 because the harmonics of a v8 cant rev as high and the fireing order in the upper rpms messes every thing up.
Just sit back and think of what this 6l v8 rumors are saying.As much power as a por/gt with a v8 is just crazzy.
Again, never say never.
I have a question, can engines be made so they have variable compression?
When it comes to detonation, compression is not the evil fiend that everyone thinks it is. Cylinder pressure is the biggest reason engines ping. I can build an engine with 20:1 compression and make it run on regular unleaded. How? Big cam overlap where the intake and exhaust valves are open at the same time (or leave the exhaust valve open past BDC on the intake stroke). This will lower the amount of air/fuel in the cylinder that has to be compressed. The engine may not run very efficiently but hopefully you understand what is happening here.
Variable valve timing achieves your goal by varying the cylinder pressure with valve timing adjustments.
NO! Compression ratio is static. It is basically, the volume of the cylinder with piston at BDC in relation to the volume of the combustion chamber. These values are not dynamic.
Imagine the cylinder is at rest at BDC and therefore filled with air at atmospheric pressure (assume 0 psi). When the piston makes it to TDC, the pressure rises (to what level is not important). Now, imagine if you were to put a compressed air hose on that same cylinder at rest at BDC and pressurized it before the piston made its way to TDC. The resulting cylinder pressure would be much greater than the first test becaue you started with more air.
The compression ratio did not change but cylinder pressure did. Make sense?
So the compression ratio stays the same, but the cylinder pressure and changeable by the valves timings.
Man, cars get complicated fast.
You can get a 600 plus hp small block V8 for $13,000 from these guys:
http://www.badasscars.com/engineprices/chevsb.html
Oops, here is a 340 cubic inch V8 engine that has 600+ hp on 91 octane:
http://www.moparmusclemagazine.com/t.../155_0310_340/
Oh wait, there's more. Here is another article that tells you how to build a 600 hp small block V8 that runs on 92 octane:
http://www.carcraft.com/howto/1004/
Uh-oh, I keep finding more and more evidence that you are clueless about V8's:
http://www.worldcastings.com/docs/03catalog/engines.pdf#search='600%20hp%20small%20block'
Here is a 675 hp small block V8:
http://www.speedomotive.com/675_hp_small_block_4.htm
Here is another 600 hp small block. 600 hp at 6,000 rpm and dirt cheap with off the shelf parts.
http://www.sporttruck.com/techarticles/84258/
Another 600 hp NA V8 that runs on pump gas:
http://www.carcraft.com/techarticles/76858/
I can go on and on and on to show you how easy it is to get power from a V8. For some unknown reason, you seem to doubt that a V8 can be made to produce much power. The above examples us an engine design that is decades old. A new V8 design utilizing multiple overhead valves and cams, variable valve timing, and silica impregnated aluminum bores or aluminum bores that are coated with Nickasil has even more potential to make big power from a naturally aspirated engine. "Freakin' damn near impossible." I don't think so.
An increase of bore alone on an otherwise properly tuned engine will increase torque not only at the peak but also on the bottom end. Why? Increased displacement causes an increase in port velocity and better cylinder filling. At higher RPM, the torque increase is not as great if there at all due to increased rotating mass and friction. Also, the larger piston area gives the combustion gasses more leverage to push on the crank. The meaning of PSI should help expalin this.
Also one also has to look at any production car on the planet that is NA its peak torque is very very strongly governed by absolute displacement. Take 100Nm/L as a good guide and highly tuned good flowing engines get maybe 110Nm/L
http://www.7extrememotorsports.com/transam/stats/
I know tuner companies can make that power
wow you brought up nascar that get a engine rebuild 3 times a week good job buddy.
IM SAYING MB WILL NOT PUT OUT A NA V8 making 600 hp
ill bet you 100 bucks it wont be 600hp NA
Increase bore and keep stroke the same is what I was referring to.
Thanks for the info Al.
With all of the advancement in engine technology these days, it is very possible that MB will produce a reliable and drivable V8 making 100hp/liter.
Just about every major manufacturer can build a NA V8 with a good bit more than 100 hp/L. Manufacturers use race engines as test beds for their street engines and take the knowledge and apply it to make a car more reliable. With modern engine management systems and variable valve timing, making huge reliable hp is not that difficult.
Yes, Mercedes can make a reliable V8 with over 600 hp. There is no doubt that they could do this. Will they, I don't know. They have surprised me many times with past engines so I wouldn't put anything in the never catagory with them. It is totally assinine for anyone to think that Mercedes couldn't build a reliable big hp NA V8 motor.
do you think that this special 600 hp v8 will last 200k miles and 20 years like almost every mb enigine ever built?
Im sure they could heck BMW in the 70's made a turbo M that had 400Hp/l
800 hp out of a 2.0 l 4 banger.
that car needed a rebuild after everyrace.
its not MB heritage to make a high strung 600 hp v8.They have never came out with any engine near 100 hp/l STOCK and wont
we have 300k miles on our 1983 300 turbo d still runs mint too.
