Tire size
04 E55
Tire size
This came from the Tires, Suspension & brake forum...
I too would really like to know if these particular sizes fit
Originally Posted by E55Soon
Anyon here try to mount 255/35 ZR19 (front) and 285/30 ZR19 (Rear) on their W211 E55??? Will they fit. I hear of people putting 20's on their cars all the time & wonder why the aforementioned sizes wouldn't work on my car?
I have the SL-65 AMG rims on my E55 and these are the same size tires I have. They fit perfectly and there is no rubbing. No gap between the fenders or anything and there is no need to roll the fenders.
THEY FIT.
THEY FIT.
04 E55
THEY FIT.
THEY FIT.
I'm also concerned that different tire companies, make their tires differently, so some might be just ok without problems while others might run into rubbing problems etc. What rubber do you have MB Fanatic? Also, have you lowered your ride? Also, any difference in the ride or handling? do you have any photos?
Yes car is lowered via Star Diagnostics at dealer (nice tech, very into his MBZ's, which is always a great thing). Also I drive with Sport II a lot of the time with Michelin PS2's on all corners of the car.
Ride is nice and smooth (a bit harsh as time progresses with wear on tires, but nothing too bad, still very comfy). Handling is greatly improved with the lowering and larger wheels and tires, car feels much more stable and looks great. The ride is so smooth in Comfort that it feels like its gliding on air almost.
I am going to try some Bridgestone S-03 Pole Position as these PS2's come to the end of their life in a year or two.
Not very helpful on my part since I can not describe how the car handles and feels to well.
04 E55
I am looking at a combo right now and wondering if it would be ok, since I know that 255 fronts and 285 rears work fine.. but would they work with 19x8.5 fronts and 19x9.5 rears ET38mm..
So the tire/rim i wanna get are 5x112, ET38mm 19x8.5 and 19x9.5 with 255/35/19 and 285/30/19..
what are the stock ET's?
I would go 9 in front and 10.5 at the rear with those tyres it would look much better...Sizes sound perfect to ME...you get much better handling and steering reponse with 255...I've tried that on my Lorinser rims and M5 as well...
Originally Posted by houston
I don't think the Bridgestone S-03's come in 255/35/19's and as well I don't think they come in 285/30/19's either...
Here are you tire options for sizes 255/35/19 and 285/30/19:
Bridgestone Potenza RE050A
Dunlop SP9000
Michelin PS2 (My choice)
Michelin PS A/S (no way)
There may be more from some other brands like Toyo or Kumho, but I didn't look them up.
Dunlop SP9000
What about Pirellies P Zero Rossso or Corsa direziontale and assimetrico...
I have of my S now and best tyres our of all I've had (Dunlop Sp 9000, Mich PS, Yokos AVS 102 -sh*t) and now Pirelli so far more comfy and less noisy tyres out of all...
PS2 I have on my M5, hook up good, especially when they are warm and WET traction OK...
I'd say out all tyres mentioned by Darren go for PS2 as well...
04 E55
THEY FIT.
THEY FIT.
What are the actual stock tire size/offset on the SL-65 AMG rims?
Also, as I mentioned a few posts up, Would ET38 be ok for our E55's?
2010 ZR1 2011 JGC Overland 2013 ML63 on order
Originally Posted by darren_dallas
Unfortunately I don't think the Rosso Direzionale or the Assimetrico have the 285/30 for the rears. I don't know about the Corsa, unless that's just another name for the Rosso.
295/30 PS2 is definitely too wide for a 10" wheel at least on my E55. I have rubbing on the inside of wheel well, and the "wiggle" that has been discussed here ad nauseum. I'm just gonna burn up the 295's & go down to 285. I have heard that a 295 Bridgestone or Pirelli will not rub as it has a slightly narrower sidewall.
