Found Some Light Volk Wheels That Look Like AMGs
Anybody know if these come in our bolt pattern?
http://www.group5motorsport.com/main...&product=VR-PS
2004 E320
Originally Posted by Accomplice8
Will that really work?
Please see following links
https://mbworld.org/forums/showthrea...1+bolt+pattern
https://mbworld.org/forums/showpost....96&postcount=5
Yes you can...think about it..112 and 114 are 2mm difference. "inserting" as it is called in the wheel world is when you drill the hole which accepts the lug nuts to a bigger diameter so you can accomodate that lug pattern.
2004 E320
Ehhhhh okay…I thought we’re talking about wheels out of the box w/o modifying them. I guess drilling out larger holes will make 5 x 114.3 rims fit, but will it be hubcentric or posses the same structural integrity? Personally, I wouldn't do it. Why not just dish out a few extra $ and have Volk custom make 5 x 112 rims instead?
Had two wheel dealers respond to say that they will fit the car. One mentioned 8.5X19 front, 9.5X19 rear, the other mentioned 10.5 rears. Neither said anything about inserting or drilling out the wheels. One of them did say that spacers wouldn't need to be used. It looks like a 30 day wait to get them and a cost around $3,000 for the set (without tires). Until I get more info. I won't know for sure.
Kevin
Kevin
Fellas, I got some good news. A distributor can order these in our proper bolt pattern, with a custom offset to allow for the 10.5" wide rears if we get 10 orders. They have to be 10 orders for the exact same size, offset and finish. He estimated a weight of 23 lbs. for these 19's, which would be, what, a 7 lb. reduction in unsprung weight? Those who want to get really wacky could do a group buy of 10 sets of 19" TE37s custom to our cars and drop over 10 lbs. per corner in unsprung weight! Thoughts?
Kevin
Kevin
Another option that is lighter but more money and doesn't require a group buy is this model with forged Magnesium centers...
http://www.upgrademotoring.com/wheels/forgedMag.htm
The only problem is that a set would be $5,000+ before tires vs $3,000 for the heavier Volk model above.
Kevin
Kevin
Former Vendor of MBWorld
Wheel pros, what size tires would fit the wider set mentioned above? What is the widest tire size you would have on a 19X10.5?
Kevin
Kevin
try the SSR GT10's...I believe they make them in 19 and 20 inch sizes..Try tirerack.com
Administrator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
2020 Audi R8 V10, 2016 AMG GTS, 2018 E63S Edition 1, 2018 Porsche GTS Cab, 2012 C63 BS
Those look very nice but don't come in a fitment for the E55.
