10,000 miles service A
///E63V10 ///F80CS ///Can-Am X3 XRS
My first time bringing it in for 10k mile service. Will they void warranty since I have after-market wheels installed? Or should I put back the stock to be on a safe side?
I would not think that the wheels are going to be a problem. The following is from an e-mail that my salesman wrote to me in response to warranty questions. Hope it helps.
"Aftermarket modifications will void the warranty on the affected component. If you do enough modifications they will flag the car with a code 8 that will require pre-approval on all warranty work at any dealership. To clarify, if you install headers and the power window goes out, it would be covered. (Non-related components) If the engine has to be removed to install headers it will void the warranty. Modifications that can be reversed like a pulley before bringing the car into service you can probably get away with. "
You shouldn't have any problems with getting maintanence type service. As can drive 55 pointed out, if the problems are unrelated in any way, they must make attempts to fix any unrelated problems.
Plus, with the 2005 cars, you're paying for service...I don't think they can say anything when it's coming out of your pocket.
