Audio Install on W211 E55 HELP!!
However, I'm not using an FM modulator. I'm going to use the AUX connection. Anyone know how to remove the head unit?
1. Pull up on transmission shifter surrounding cover...
2. Remove ashtray...you have to grip the side walls of the ashtray with your fingers and just pull outwards.
3. Remove CD Changer...there are 2 torx screws holding the changer down. I forget exactly what size torx screw...I think T20 if I'm not mistaken. Disconnect the wires and do not bend the fiber optics cable.
4. Remove 2 torx screws that hold the COMAND in place. COMAND should slide out after removing the screw.
I think those are all the steps to remove the COMAND unit.
-Chris
Shouldn't be too hard. I did the EURO COMAND swap in about 20 mins. Some of the CD changer connects are hard to pull off, but just be patient and don't try and yank anything off.
