*** Oil in the throttle body ***
I didn't do my homework too good on this project. I got as far as mounting the bracket for the catch can..
The stock PCV hose that runs from the driver's side valve cover to the throttle body intake hose is approx 0.75" O.D... Inner diameter is somewhere between 0.5" and 0.625".. Meanwhile, the hose and fittings that AMW and every other Catch can supplies is 3/8"...
I need some advice.. Do you guys think I would be introducing a restriction if I try to find something to adapt the 0.75" hose to the 3/8" connector on the catch can?
If so, should I try to get the catch can re-drilled and tapped for a 0.75" hole and fitting?
Let me know what your opinions are...
- Bob
- BobShould be able to get it done this weekend.. Hopefully..
- Bob
I went to Home Depot yesterday and after trying a few different NPT fittings, the 0.5" with the 5/8" barb is the proper fit. The 5/8" fitting seems to match the diameter of the stock hose.
Here are the issues:
- The stock hose has a flare on the end of it. It looks like the flare fitting is 0.75" on the throttle body and the crank case. I dont know if I can press a 5/8" hose onto the 0.75" fitting on the throttle body tube.
- I cant find the plastic NPT fittings. All I found was the brass ones which I dont really want to use. I need to locate an automotive parts store that has plastic NPT fittings in straight and 90degree shapes.
Also, I couldnt find a proper tap size and since Monday is a civic holiday up here I have to wait until Tuesday to pick up the tap and other hardware and try this again.
Any idea on what to do about the flare fitting?
- Bobhttp://www.mcmaster.com/
Any chance you can help me locate what I am searching for.
- Bob
- BobI bought a complete 60piece tap kit but as luck would have it, 1/2" tap is the biggest it has..
I need to locate a 1/2" barb to 1/2" NPT fitting in order to make this work. If I can't get it locally (which it doesnt look like I will be able to) I will have to order from McMaster.
This is taking alot longer than I wanted, but I want to make sure I do it right.
Yeah right..
I want to make sure I do this right so I need to ask some opinions from the "engine builder" types on here...
I've seen some 700rwhp and 800rwhp supercharged corvettes install these AMW catch cans right out of the box.. AMW ships with a 3/8" hose.
If you are supposed to evacuate the PCV vapours as quickly as possible, why do all these high-horsepower cars run 3/8" hose meanwhile the E55 has a 5/8" hose????
I've got fittings in my possession that will accommodate a 1/2" hose and I also have the 1/2" tap necessary. What would be the negatives to me installing this 1/2" hose rather than trying to get a proper 5/8" hose and a 3/4" tap to drill out the threads ( I cant find a 3/4" tap that I can use anywhere)????
HELP!!
HELP!!
- Bob
www.fluidsysteminnovations.com. If not . it may spark some thought for future projects. ___PTE___
I got quoted $710 CDN for the parts for the stock oil cooler so I'll see what it will cost to build a custom one.
I dont see any of the so called "euro tuners" resolving true issues just selling wheels and generic tunes.
I just ordered the AMW oil catch can for the SRT8, due to a severe oil contamination in the manifold. Upon removing the manifold oil puddled out!! Both vehicles "puff" blue smoke occassionally on start up and got me researching the issue. I guess I'll try to adapt something but had to resurrect your thread.
http://www.accmachtech.com/pcvcatchcans.htm
I *had* the catch can installed.. I had to remove it becuase in order to install it properly, you need to feed 2 lines into it... and 2 lines out.. The catch can that I have is pretty much the best one you can buy in terms of design.
The hose that runs from the driver's side manifold needs to be routed there, and so does the hose that runs into the bottom of the TB. Then you need to plumb 2 lines back from the catch can into these 2 locations.
On a small catch can like the one I have its hard to get all of these to fit.. especially since the hoses are 0.5" so you need to drill & tap some pretty big NPT fittings to make it work..
I'm looking for a way to make this work, but I might buy a larger unit or have one custom made to my specs..
Sorry I cant be more helpful.. this is one of these things that I had to put on the backburner in order to work on some other priorities..
So I'am lead to believe that the hose on the drivers side is the make up air for the crankcase. That hose can be removed from the intake tract and a filter attached to the end. I havent located it yet BUT the hose under VACUUM....will be attached to the manifold or directly to the intake tract and it will be connect to this point by a PCV valve. When they are not working properly the crankcase pressure will "backup" and find its way (path of least resistance) to the one leading to the throttle body.
So the ideal set up is provide make up crankcase air (as designed) from the hose currently under the throttle body tube but disconnect it and put a K&N type filter on the end....(also plugging this hole)...then locate/place a catch can between the hose that connect the PCV valve to the vacuum source.
VRUS.......only one catch can is required. The hose that has the Positive Crankcase Ventilation Valve is the one that a oil seperator/catch can is required! The other hose is for fresh air that is required to complete the circle of bad contaminated crankcase gas out and the other completes the circle by providing a source of new/filtered clean air.
