M5 vs. chipped E55 AMG video
Dont forget for the e63 to take advantage of its NA power will need shorter gears.The m5 revs very high to make up for its short gears.
If you watch the vids of the m5 vs those ferrari's you can really see how well they did up top with there short gears and high red line.
from 7-8.4k is where the m starts to really pull on them.
The 550m in one of those videos has way more tourqe than the m5 with almost the same hp.It also weighs about 200lbs lighter.
Received 1,097 Likes
E55, GLS450, GL63, GLE350
Originally Posted by athlon70
The 7 speed can't handle the torque output.
e55211 traded in for CLS55
Originally Posted by E55AMG99
The current 7 speed. MB will beef it up before putting behind anything more powerful than the NA 55 motor in a heavy car.
Originally Posted by BlownV8
The M5 revs high because that's where it makes its hp/tq due to its relatively small displacement. The E63 will not need to rev as high to make the same power due to its displacement. hp=tq*RPM/5252
If you redline 4th in the m 5th gear comes in at 7k(very close gear ratios)This is why MB needs to use higher red line to make up for its shorter gearing
its max tq is at 6k and 80% of it is from 3k-5k so what do you mean when saying bmw needs highrev to make up for displacement.All m engines are high rev by nature and have a pretty flat tourqe curve.
#32
Originally Posted by skratchmyass69
yes and BMW is using high rev with shorter gearing to make it how fast it is.
Of course, you can try: Let's see you explain using scientific terms exactly why BMW's method of producing high acceleration is superior.
This should be entertaining.
#33
Don't be so hard on him. Physics was a really tough subject! .....NOT!
Anyway, I'm waiting for the F1 comparisons any minute.
#34
You take everything and turn it into **** impro.I said they will need to use hi rev like the m5 and use shorter gearing.Isnt the new MB engine revving over 7k?
im sure mb is working on the best ratios with the engine.My point of the m5 is the 5th and 6th gear shifts in that car are good for like 15 mph each(very close ratios)
Wut do you think is going to happen with the higher tourqe engine at lower speeds using shorter gearing?
impro watch the vid of the m5vs 550 and watch how quick the m pulls shifting into 5th and 6th.7th is an overdrive for cruising
with that much tourqe they cant get as agressive gearing with out more wheel spin.
#35
-i suppose one advantage would be a "lighter" drive train in terms of both mass and in rotational inertia.
-disadvantage would be economy/efficiency because of increased frictional losses coming with higher engine speeds.
there are many more pros and cons but it in the end it comes down to what you prefer
#36
#37
Originally Posted by reggid
both will be able to spin the wheels in a low gear so its not a real advantage either way
the m5 has the lower tourqe and is able to use very short gearing and the higher rev to make up for it.
4th 5th and 6th in that car are good for 50 mph(very short) it has the rpms to alow them to do this.
I cant wait to see the e63 can do with its setup
#38
thats the point im tryin to make.The next mb wont have as agressive gearing like the m5 does because of its tourqe adv.
There is no advantage in using either setup in the low gears because of traction issues so i believe AMG can still gear the new 6.3L agressively (not as agressive as the new m5 becasue it won't rev as much but they don't need to gear it too agressively anyway) in 3rd,4th.......etc where there won't be traction issues.
In the end crank torque and gearing are just used to maximise the rwhp at any given speed.
#40
#42
Originally Posted by kip
#43
Mercedes-Benz A170 CDI
go to free-codecs.com and download this....
http://www.free-codecs.com/download/...k_All_in_1.htm
<WARNING> BY CLICKING ON THIS LINK YOU ARE AGREEING TO THE TERMS AND CONDITIONS OF THE WEBSITE "FREE-CODECS.COM" AND THE CONDITIONS OF THIS POST. THE LINK IS PROVIDED TO YOU FREE OF CHARGE. THE PROVIDER, "Some lameasss--->"Bilal" ACCEPTS NO RESPONSIBILITY WHATSOEVER WITH REGARDS TO ANY SUBSEQUENT DAMAGE THAT MAY OR MAY NOT OCCUR TO YOUR COMPUTER SYSTEM OR LIFE OR EMPLOYMENT STATUS OR SEXUALITY. BY CLICKING ON THE LINK YOU ARE VEHEMENTLY ACCEPTING THESE TERMS AND PROCEED AT YOUR OWN RISK.
THESE TERMS AND CONDITIONS ARE LEGALLY VALID WITH REGARD TO ANY APPLICABLE STATUTES AND COMMON LAW PRINCIPLES ONLY WITHIN THE LEGAL SYSTEM OF DJIBOUTI.
Seriously though, the website seems legit as they have their own forum<----how naive is that! Seriously, it seems legit....yeah right, ok I'll stop now....
#44
