W211 Technical Service Bulletins
2003 E55
Safety Recalls
TSB Number & Issue Date TSB Title
2004050014 OCT 04 Recall - SBC Hydraulic Unit Reprogramming
2003080003 AUG 03 Recall - Steering Coupler Pinch Bolt Torque
General Recalls
2004070019 OCT 04 Campaign - Central Gateway Module Reflash
2003020003 JUN 03 Campaign - Front Door Module Replacement
2002090005 DEC 02 Campaign - Instrument Cluster Module Flashing
Service Bulletins
P-54_21-137 MAR 05 Electrical - Battery Control Module Reprogramming
P-42_46-58 MAR 05 Brakes - Sensotronic(R) Brake Control System Activation
P-27_55-50A FEB 05 A/T - Harsh Engagement/Buzzing Noises
P-83_30-74A FEB 05 A/C - Musty/Moldy Odors
P-72_10-32B JAN 05 Body - Front Door Lock Rattling When Locking
P-54_21-133 JAN 05 Lighting - Trunk/Cargo Light Inoperative
P-54_21-134 JAN 05 Antitheft - Interior Lights ON After Alarm Activation
P-27_60-43 JAN 05 A/T - Rough Converter Engagement/Droning/Buzzing Noise
P-82_64-385A DEC 04 Audio System - Multiple CD Changer Malfunctions
P-82_62-361A DEC 04 Audio System - Speakers Crackle With Radio ON
P-30_30-61 DEC 04 Cruise Control Inoperative
P-72_29-38 DEC 04 Electrical - Power Seat/Mirrors/Windows Inoperative
P-54_21-125 DEC 04 Instruments - False Messages Displayed
P-82_10-419 DEC 04 Lighting - Condensation in Headlamps
P-54_65-130 DEC 04 Parking Assist System - Triggers For No Apparent Reason
P-32_25-19 DEC 04 Suspension - Shock/Strut Replacement Guidelins
P-42_46-53 DEC 04 Brakes - 'Brake Malfunction SBC Visit Workshop' Message
P-42_46-46B DEC 04 Brakes - Sensotronic Brake Control (SBC) Bleeding Proc.
P-18_00-17C DEC 04 Engine - Approved Engine Oils (Addition)
P-42_46-32B NOV 04 Brakes - Whistling Noise When Pressing Brake Pedal
P-82_64-414 NOV 04 Audio System - CD Retrieval From Changer Unit
P-82_70-346B NOV 04 Cell Phone - Inoperative/Locks-Up
P-33_15-16 NOV 04 Steering - Steering Wheel Twitch on Low Speed Braking
P-15_40-54 NOV 04 Charging System - Insufficient Charging
P-42_46-50 OCT 04 ABS - Sensotronic(R) Brake Control Diagnosis/Repair
P-80_50-31A OCT 04 Antitheft System - Acoustic Arming Signal Disabling
P-82_62-325D OCT 04 Audio System - Inoperative/No Right Channel/Memory Inop.
P-82_62-407 OCT 04 Audio/COMAND(R) Systems - Noise/Erratic Operation
P-27_00-47A OCT 04 A/T - 722.6 Oil Leaks From Electrical Connection
P-77_10-24 OCT 04 Body - Sliding Roof Water Leaks/Rattles
P-54_10-117 OCT 04 Electrical - Under Voltage Switch Off Consumers Message
S-07_61-38F OCT 04 Engine/Transmission Controls - SCN Coding
P-82_30-399 OCT 04 Windshield - Blistering Near Rain/Light Sensor
P-82_60-382 SEP 04 Audio/Cell Phone - Erratic Operation
P-82_62-387 SEP 04 Audio System - Interference Noise From Speakers
P-82_70-248A SEP 04 Cellular Phone - 'No Service' Message Displayed
P-83_20-72 SEP 04 A/C - Erratic Rear A/C Operation/DTC's Set
P-54_21-113 SEP 04 Battery - No Start Condition Due To Quiescent Drain
P-77_20-19A SEP 04 Body - Sliding/Panoramic Roof Synchronization Loss
P-82_70-375 SEP 04 Cell Phone - Intermittent Power ON/OFF/Erratic Operation
P-82_60-360 SEP 04 Audio System - Loss of Sound
P-82_70-338A SEP 04 Cell Phone - Echoing/Noise During Hands Free Call
P-82_85-389 SEP 04 COMAND(R) System - Unit Switches OFF Regularly
P-82_30-366 SEP 04 Wipers/Washers - Wipers Chatter/Noisy After Blade Change
P-46_10-18 SEP 04 A/C - Steering Wheel Heater Not Working Properly
P-33_15-15 AUG 04 Steering/Suspension - Torque Strut Replacement Parts
P-82_00-260A AUG 04 Audio System - CD's Won't Play or Eject
P-83_00-70 AUG 04 A/C - Inoperative/Codes Set/AC OFF Lamp Illuminated
P-91_60-66A JUL 04 SRS - Warning Lamp ON/DTC's B9223/B9243 Stored
P-42_46-43 JUN 04 Brakes - Squeaking Noise On Application
P-42_46-27D JUN 04 ABS - Buzzing Noise During Pressure Build-Up
P-82_10-365 JUN 04 Lighting - Headlamp Reflector Loose
P-82_62-357 JUN 04 Audio System - Intermittent Sound
P-47_30-29 JUN 04 Interior - Knocking Noise
P-82_85-363 MAY 04 Instruments - Clock Setting Procedure
P-91_60-74 MAY 04 SRS - Coding Unnecessary
P-42_46-41 MAY 04 Sensotronic(R) Brake Control Unit - Service Precautions
P-82_10-343A APR 04 Lighting - Fog Lamp Beam Screen Cap Loose
P-82_10-344 APR 04 Lighting - Left/Right Brake Lamp Brightness Difference
P-54_00-71C APR 04 SRS - MIL ON/Multiple DTC's Found
P-67_29-10 APR 04 A/C - Rear Window Won't Heat in the Upper Area
P-82_60-259A APR 04 BCM - P9386 Control Module Diagnosis Stored in DAS
P-82_85-325B APR 04 Audio - Intermittently Not Functioning
P-46_20-16 APR 04 Steering - Leaks at Line/Rack Housing Connection
P-42_46-38 APR 04 Brakes - Software Patch Necessary Before Bleeding System
P-82_95-322A APR 04 Communications - 'Tele Aid Not Active' Displayed
P-82_85-322 APR 04 Navigation System - Installation
P-82_20-336 MAR 04 Interior - Sliding Roof Switch Cover Cracks
P-82_85-332 MAR 04 Navigation System - Slow to Start Upon DVD Insertion
P-42_20-35 MAR 04 Parktronic System(R) - Intermittently Inoperative
P-46_10-15 MAR 04 Interior - Steering Wheel Heater Inoperative
P-01_45-15 FEB 04 Engine - Oil Leak
P-00_45-77 FEB 04 Interior - Squeaking/Creaking Noise Kit
P-82_95-305 FEB 04 Emergency Contact/Alarm System - System 'Runaway'
P-54_18-108 FEB 04 Starting System - Engine Does Not Start
P-07_00-28F FEB 04 Engine Controls - Lack of Power/Hesitation/MIL ON
P-33_15-10 FEB 04 Steering/Suspension - Alignment Requirements
P-82_85-301 FEB 04 Navigation System - DTC D300 Explanation
S-01_30-15 FEB 04 Engine - Cylinder Wall Damage Assesment
S-49_10-08 FEB 04 Exhaust System - Rattling/Hissing/Humming Noises
P-40_10-43 JAN 04 Tires - Michelin Pilot Sport A/S(R) Tires Not Approved
P-54_21-89B JAN 04 Charging System - 'Battery: Visit Workshop' Message
P-54_65-104A JAN 04 Parking Assist System - Triggers for No Reason
P-47_10-27 JAN 04 Fuel System - Fuel Filler Cap Hard to Remove/Install
P-30_20-61 DEC 03 Engine Controls - MIL ON/Limp Home Mode/DTC's Set
P-54_10-106 DEC 03 Battery/Charging - Error Message Displayed/DTC's Set
P-82_30-316 DEC 03 Wipers/Washers - Erratic Intermittent Wipe Explanation
P-82_10-258A DEC 03 Lighting - Front Turn Signal Lamps Inoperative
S-18_00-16A DEC 03 Gasoline Engine - Oil Sludging
P-82_95-295 OCT 03 Communication Platform - Mobile Identification Number
P-82_62-226A OCT 03 Audio System - Intermittent Loss of Audio
S-54_21-101 OCT 03 Engine Controls - ECM Flash Process Change
P-88_50-33 SEP 03 Body - Trunk Lid Springs Back When Opened
P-54_18-98 SEP 03 Battery - Disconnecting Requirements During Vehicle Svc.
P-82_10-255 AUG 03 Lighting - Premature Headlamp Bulb Failure
P-88_50-32 AUG 03 Body - Water Drips Into trunk With Trunk Lid Open
P-61_10-02 AUG 03 Body - Water leaks Into Trunk
P-54_10-90 AUG 03 Battery - Diagnostic Troubleshooting Procedure
P-82_95-273 JUL 03 Communications Platform - DTC D640 Set
P-82_95-274 JUL 03 Communications Platform - DTC D662 Set
P-82_10-269A JUL 03 High Mount Stop Lamp - Water Leaks Into Trunk
P-82_85-264 JUL 03 Navigation System - Inoperative/Erroneous Guidance
P-82_95-251A JUL 03 TeleAid(R) System - 'TeleAid Defective' Displayed
P-82_95-267 JUL 03 Cell Phone - Erroneous Hands Free Fault Code
P-14_30-15 JUL 03 Emissions - MIL ON/DTC P2003 Stored in Memory
P-82_10-257 JUN 03 Lighting - Headlamp Bulbs Inoperative
P-82_95-235A JUN 03 Communications Platform - Replacement Instructions
P-82_30-254 JUN 03 Wipers/Washers - Wiper Blades Noisy
P-82_95-250 MAY 03 TeleAid(R) System - No Audio Mute When Button is Pressed
P-20_10-23 MAY 03 Cooling System - Water Pump Leakage
P-82_95-242 APR 03 Communications Platform - DTC D003 Explanation
P-62_00-03B APR 03 Electrical System - Various Malfunctions
P-82_70-222 MAR 03 Cell Phone - Phone Won't Fasten Into Cradle Holder
P-32_22-15 MAR 03 Air Suspension - Low Ride Height in Cold Temperatures
P-67_00-09 MAR 03 Body - Windshield/Rear Glass Body Seam Corrosion
P-54_18-84 MAR 03 Battery - Disconnecting During Service
S-07_61-27A MAR 03 Engine Controls - ECM Reprogramming Procedure
P-82_60-227 FEB 03 Audio System - Static Noise With Rear Defroster ON
P-80_57-20 FEB 03 Audio System - RF Interference Explanation
P-46_20-10 FEB 03 Steering Rack - Connector Leaks
P-54_21-80 JAN 03 Electrical - Rear Fuse Panel Cover Difficult to Remove
P-54_15-79 JAN 03 Electrical - Wheel Well Fuse Box Loose
P-82_10-218 JAN 03 Lighting - Dust/Debris Inside Tail lamps
P-54_10-78 JAN 03 Electrical - Automatic Switching ON/OFF Explanation
P-82_60-214 DEC 02 Audio System - No/Poor FM Reception
P-83_55-65 DEC 02 A/C - Compressor Cycles Frequently
P-80_61-17 NOV 02 Keyless Go System(R) - System Initialization
P-54_21-74 NOV 02 Engine Controls - ECM Programming Procedure
P-82_62-169B OCT 02 Audio System - Various CD Player Malfunctions
P-72_10-28 OCT 02 Power Locks - Lock Knob Jumps Up and Down
P-62_25-04 OCT 02 A/C - Water Entry Into Footwell/Electrical Malfunctions
P-82_95-206 OCT 02 Communications Platform -Tele Aid DTC Codes
S-82_70-135B OCT 02 Fiber Optics System - Configuration/Version Coding
S-07_08-001 JUL 02 Engine Controls - Software Calibration Number Coding
2004 E55
Safety Recalls
General Recalls
2004070020 OCT 04 Campaign - Front Wheelhouse Drain Modification
Service Bulletins
P-82_85-437 FEB 05 COMAND(R) System - Erratic Operation
P-82_85-424 JAN 05 Navigation - Navigation Unavailable/No DVD Inserted Mssg
P-82_85-374A OCT 04 Navigation System - Erratic Operation/Inoperative
P-82_85-404 OCT 04 Navigation System - Inaccurate/Malfunctions
P-91_10-80 OCT 04 Interior - Memory Seat Faults/Erratic Movement
P-27_60-44 SEP 04 A/T - Implausible Downshifts
P-54_10-116 JUL 04 Electrical/Battery - Solar Charging Panel Installation
P-91_60-71 APR 04 SRS System - Occupant Classification System
P-82_60-309 MAR 04 Audio System - Satellite Radio Installation
P-82_85-288 SEP 03 COMAND(R) System - Unable to Enter New Destination
2005 E55
Safety Recalls
General Recalls
Service Bulletins
P-91_60-85 FEB 05 Restraint System - Seat Belt Lamp ON/Chime Sounds
S-07_08-43A OCT 04 Engine Controls - CVN Recoding After Module Replacement
P-82_85-383 SEP 04 Navigation System - Fiber-Optic Cables Missing
SuperChargerE55 (08-21-2019)
How about us 210 guys? Do you have data on the 02? I'd like to think that the list would be much shorter. I hope MB is paying attention. Reliability should be part of the ownership experience. Thanks for all your effort, Ricky.
W203 slightly modified
Ricky I think you should be more considerate of the fact that some people might fear buying a Benz when seeing all this. You may in fact create buyer panic and that is something working against the brand.
Only qualified technicians have the experience to know which bulletins are relevant and which ones are unimportant. Casual forum readers have no such training and on face value it looks like the cars are minefields.
That's not my intent, I just post it as information. That's how it should be taken as.
I've had many dealers casually tell me that there is no fix for my car for a particular issue, and they suddenly become aware of a resolution once I can help nudge them in the direction.
I don't blame them for just saying that there is no fix, how many people do you think come in a day for the same problem. Probably a lot cheaper and easier to say 'we don't have a fix for that' or 'we can't find that problem'
YMMV though
YMMV though
Muhtish (05-09-2022)
'06 CLS55 P030
Not really, Dealers get paid to fix, repair, attempt repair, throw parts at, cars under warrenty!! Mb pays. Dealers dont get squat to tell people to go away..they want to fix ur cars...they just dont want to attempt repairs that are not authorized, recomended, or approved by mb----then they hurt themselves...and dont get paid by anybody.
Poor Quality
I support the notion that lets buyers see how dismal MBs quality has been...and even more to the point....what a low interest they have in solving the problem....I have a 2001 E55, went to dealer to see about 2006 model...asked about the quality issue....sales guy said there were none...I responded by pointing out that this issue has been acknowledge by DB....at least in the Wall Street Journal.....his response was that if quality was poor why are they selling so many cars....and PT Barnum had the answer for that...
John
John
'06 E55, '05 SLK55, a few others
Well, I'll say this. I just traded my '02 for an '06. The '02 was pretty much problem free except for an occasional (and rare ) glitch in the factory COMAND that blanked the sound for a second or 2. Had more trouble sorting the blower than with the car itself. The blown '02 was faster than a stock W211, not much, but faster. The '06 has been delivered to a dealer this morning for 3 problems, only 1 of which is not an actual problem with the car:
1. Tele-aid non-op due to inputting the wrong registration code by the delivering dealer.
2. Long hesitation to engage drive after backing out of my garage from a cold start. I mean, a thousand one, a thousand two, a thousand three, and CLUNK, I'm in drive.
3. A distinct stumble or hesitation from a start, and sometimes at the 1-2 shift as well.
Don't know guys, but 50K or (in this case) 100K, and that should not happen. I'll hope for the best I guess.
Did you take it to the dealership?
I was at 550 when I dropped it at Silver Star yesterday. Hope all is well today. The SA said he has seen several 55's come low on trans fluid which would explain the slow reacting trans?? Maybe a Monday car.
......................And so it starts. Let's see, Tele-aid fixed since there isn't anything wrong with the car, just a bone head typing job by someone at FJ.
Tranny delay in finding a gear- "Well, we tried it cold this morning and it only hesitated a second or 2" ----In other words, we have no idea, wait for it to break and strand you.
Stumble or hesitation on accelerating----"Maybe it's ESP cutting the power. You know this thing will cut the power if you're spinning the tires" Again, no clue. I knew I should have kept the blown W210.
2008 Z06
I just got a new service request for a recall in the mail today.
Service Campaign #2006-030011
Software for the engine control unit needs to be upgraded to correct a potential malfuntion which could render the secondary air injection pump replay inoperable thereby affecting the proper operation of the secondary air injections pump.
Just letting you know!
2003 MB E55
Warranty Coverage Addendum
Today I got this in the mail (2003 E55):
Warranty Coverage Extension
(SBC/Electro-Hydraulic Brake System Hydraulic Pump)
The following applies to all model year 2003-2006 E-class, SL-class, and model year 2006 CLS-class vehicles equipped with the SBC/electrohydraulic brake system.
The Mercedes-Benz New Car Limited Warranty coverage on the hydraulic pump within the SBC/electro-hydraulic brake system is extended to 10 years with unlimited miles from the vehicle's warranty start date. Other components of the SBC/electro-hydraulic brake system are not covered by this warranty extension.
This extension of the Mercedes-Benz New Car Limited Warranty applies to these vehicles regardless of ownership. All of the other warranty terms apply to this extension.
Great. I've had great luck with the car, but this is a massive red flag to me, along with the long list of TSB's. Good thing I've got the extended warranty, but this list is simply too long.
Carrera S, anyone?
Carrera S, anyone?
