Race Cats going in
Stock is 2.75" and I am using some of the stock piping around the rear muffler so I was just going to stick with the stock piping diamter.
You forget that we have a TRUE dual exhaust and have 2.75" for each bank of cylinders. We'll be well over 1000bhp before we start choking out our dual 2.75" pipes
There are also a few other reasons I'm sticking to stock sizing - bigger is not always better my friend.
-m
-m
The reduction from 3" to 2.75" will cause a bit of reverb (backpressure) so I dont expect any low end torque loss.. We'll see if I'm right...
I've seen supercharged cars choke on 2.5" and 2.75" tubing on the dyno at 600rwhp. I want to support 700hp so I need 'dem BIG pipes.
Good luck my friend... please post everything!
http://www.burnsstainless.com/
Good Luck -
- BobSorry did not see that vrus had already posted this Co's Web address.
As far as coating the SS exhaust, do just what is in the engine compartment for heat management purposes, after that you want to dissipate the heat out of the system, as much as possible, to reduce the pressure and increase flow. SS is a very poor conductor so you want to leave as much of it uncoated as possible.
- Bob
- BobIn otherwords, if I took 3" pipe and made it straight out to the tailpipes with no catalytic converters and no mufflers, that would give me 0% backpressure right? Well, you will probably lose a heck of a lot of torque doing that wouldn't you? This is the assumption I am making...
I want just a bit of backpressure in the system so that I don't lose the torque down low.
The reason for wanting to ceramic coat the exhaust system is for 2 reasons:
1) It helps to keep the undercarriage and radiated areas cooler.
2) Coating the pipes keeps the heat inside the tubes. The hot air maintains a higher velocity than cold air.. Or am I completely wrong about this?
FYI: Flow through the exhaust system is not a continuous stream of hot gasses. It is a series of discrete pressure pulses that occur due to the opening and closing of the exhaust valves. These pulses are characterized by a very high-pressure leading edge and a very low-pressure trailing edge. This is what causes them to move down the pipe. The low-pressure trailing edge is what causes the scavenging effect. As one exhaust valve closes and the next one opens, the low pressure helps pull the gas out of the cylinder, which takes some of the load off the piston and frees up a little power. But, most V8 engines fire on alternating banks, which lessens the scavenging effect. That's where the X-pipe comes in. It allows the opposite exhaust bank to see the previous pulse and aids in scavenging. Ideally, you would like these pulses to line up one behind the other in a steady march down the pipe w/o hindrance. But, life as we know it prevents that on street machines.
On the back pressure issue, yes, ideally you want ZERO back pressure on F/I motor. The Lysohlm Supercharger will develop all the bottom end torque (cylinder filling) you need.
- Bob
As promised I will provide a pic and some thoughts. Like I said right from the beginning I will share good or bad whatever I find...
Performance:
First the good news... NO CHECK ENGINE LIGHT!! YEAHHH!!! We got the placement of the O2 sensors perfect because so far I have not heard of anyone getting away with using 1 set of race cats and avoiding a check engine light. That part is taken care of.. I am very happy about that.
Now, the bad news... My first impression was disappointment to be honest. The car felt slower. Much slower! Was I spinning my tires uncontrollably?? Was the X-pipe too big and just taking away all the torque down low? Did I increase the flow so much that I leaned the car out even more? I have a nasty suspicion that the last one is the problem... I think the A/F is just too lean now.. I was at 13:1 in the lower RPMs.. I have a feeling I dipped even lower. The engine temp was at its normal 100C - 105C. It should have been at least 10C cooler with the improved efficiency. That's what leads me to believe its an A/F problem. It leaned out more and caused the engine temp to go up.
The car felt like it was getting a bit quicker after an hour or so behind the wheel.. Maybe the ECU still needs to relearn? After I had the headers installed, it wasnt until the next morning that the car was at its optimal performance level.. I'll see what happens on the drive to work tomorrow.
I will have to throw it on the dyno on Thursday or Friday and see what happens. I have a feeling I will have to get the ECU remapped for more fuel and ignition advance.
Sound:
Noise level was unbelievably QUIET! I was floored when I started the car.. I couldn't hear it.. I was like.. WTF ??
Anyways, the huge X-pipe that I have seems to have taken out all the noise in the car. It has a very raspy, mechanical sound to it at WOT (really hard to describe but its like nothing I've heard before). At idle, you can't hear the damn thing!! Can you believe it? 1 set of race cats, 3" straight pipe, no resonators and the SOB is QUIET????
Conclusion:
I will have to wait until tomorrow to make my final decision on it. I may get the shop to mock up an H-Pipe to put in place of the big X-pipe and see if it makes a difference.
You exhaust GURUs.. Look at the pic below and tell me what you think about the X-pipe and layout. Do you think the design and layout is good or is there some suggestions on how to make it better?
P.S-> This is a mockup so it isn't what the final product will look like in terms of weld or quality... And, the final product will be coated once I am done testing and find the best setup for power.
P.S.S-> This setup was done with 304 stainless and not the 321 stainless.
http://hyperphysics.phy-astr.gsu.edu/hbase/pber.html
What we're referring to is more like water flowing through a hose. The higher the pressure inside the hose, the more water that flows.
BTW, Thank you for the technical link.
- Bob
Do you think the X-pipe having a very large cross section at my current horsepower level is inappropriate? I know it will work well at higher power levels, but maybe it is just too big for right now? What do you think?
Where are the racecats installed? Before the x-pipe right?
Victor, that's great the check engine light didn't come one. I'm guessing since they're race cats the O2 sensors and ECM are still working to adjust A/F to compensate based on what the last O2 sensor tells the computer. Do you think this could be contributing to your leaner-than-expected A/F?
BTW, visually the setup looks great. A work of art and you're not done yet.
Cheers,
Darren
Keep us posted.
As I suspected, I think I am just way too lean now for some reason. My short term Fuel Trims on both banks were 99.2% which means it is VERY LEAN. The ECU is trying to compensate by dumping more fuel but I dont think with the stock programming it is within its range of values. Just guessing....
The second thing is.. I had another thought last night.. I should of changed the location of the X-pipe. I am going to put the X-pipe where the resonator delete pipes are and put straight 3" pipe where the X-pipe currently is. The exhaust gases get cooler as they travel further away and slow down. Having them enter that big X-Pipe chamber closer to the front of the car is probably not the best thing.
P.S-> This car was making around 550hp at the crank and the A/F was already out of whack. I wouldn't be surprised if I approach 600hp at the crank with proper A/F tuning at the stock boost levels with this new exhaust setup.
I wish I could buy the ECU tuning equipment... Anyone have one for sale?
I might have to go on the dyno to get a "reading" and see where I am at compared to last time.
