Free Cooling Mod
Here's what I did. I removed the hood liner to allow heat to radiate through the hood. I removed the rubber insulator surrounding the engine compartment to allow hot air to escape out the hood vent. The whole thing took about 15 minutes.
I went for a spin and noticed the engine temp took longer to reach the usual 90C. This engine sounds simply beautiful with these items removed. I cant describe it just do it and listen for yourself. I think Mercedes made a mistake insulating the sound of this engine and in turn trapping heat buildup in the engine compartment. I can now feel the heat radiating out the hood vent after I shut her down.
It looks like you can take this mod a few steps further by re routing some of the wires under the hood vent and removing the insulation surrounding the engine compartment and placing a few holes to allow even more heat to escape and make its way out the hood vents.
Joe
As far as messing around with a $90,000 car and possibly voiding my warranty is concerned, what then do we say to all the members who have installed after market pulley's, ecu reprogramming, evo cooling kits, headers, exhaust systems and on and on.
If Mercedes engineers put the double fire wall there to protect me from a possible engine fire I'll take my chances and simply rely on the first fire wall. I really didn't remove the fire wall only the hood insulation and the surrounding rubber seal to let the heat escape from the hood vent.
I still not convinced that what I did will have any after effects other then reducing under hood temperatures as opposed to increasing them with an aftermarket pulley and upping the boost on the engine. Again this was only a 15 minute procedure that's easily reversible.
I would like to urge someone else to try this and report your finding. Even if its only temporary. I really think you'll be amazed at the amount of heat that's being evacuated from the hood vent once these items are removed.
Joe
Removing the clips is easy. Just wrap a little electrical tape around the tip of a flat head screw driver, carefully pull back the insulation to expose the first clip and poke at the little nipple on one side while gently pulling on the insulation. Then poke at the other side where the second nipple is and it should release. Continue this until there all removed and then remove the plastic piece that covers the vent. Now just remove the rubber gasket surrounding the engine and this will create a gap for the heat to escape out the hood vent.
Joe
I guess to me the real questions is, WHY? What are you gaining by doing this?
Obviously engine mods are done to make the car faster with measurable results... even though some of them are very questionable.
Its not like the car is having heat soak problems and the engine is stalling... that the A/C is not working... or that plug wires are melting... I have no doubt it gets hot under there.... but that's why MB runs their cars in death valley for weeks. If there was a real issue, don't you think that some of the hundreds of MB engineers would have figured it out? If something is going to fail or power is being robbed, don't you think one of the engineers would say "hey we should remove that blanket or change it for a thinner one"?
My point is that $90K gets you a well engineered car. Especially in a Mercedes. I would be shocked if there is a real issue that was just neglected and now a pair of pliers is solving the problem. I have never seen Brabus, Renntech or Kleemann remove this, even after mods that create more heat... There may be a valid reason for that.
Gunite don't take me the wrong way man, I am not trying to knock what you are doing... I have done many things like this myself in my race cars... and I like to tinker myself as well... so I am with you... but I don't see the benefit of this one.
GUNITE- Well just did it, so what should I keep an eye on and whatnot.
Also- I have a 3m clear bra, don't want to take any chances with discoloration.
- Bob
I didn't notice any adverse effects on the A/C. Since the hot air is continually rising and escaping I doubt its mixing with the A/C unit there on the left. How do other car manufactures deal with this when they don't encase the engine inside a thermos.
I considered only removing the rubber molding and plastic cover over the vent but after feeling the temp. of the hood after making some runs it just doesn't seem like an issue.
I appreciate the feedback.
Joe
I dont think the risks are worth this one... but thats just my 2c.
Rgds Steve.
Joe
I also thought of doing this. I've removed hood insulation on a few of my cars before but because of the high heat the motor generates and the fact that my car is black, I didnt remove it for fear of causing some paint bubbling.
I think it's a good idea personally and was thinking of pulling it off and coating the hood with some thermotech heat wrapping.. It is much lighter than the factory stuff and I believe it also acts as a fire retardant.
I see you have a black car also.. I am feeling a little more confident now that you mention you didn't notice an increase in hood temps.
Let me know what you think in a few more days of driving with it off.
There are all sorts of fixes, but they all remind me of the things you do on a chevy... not on an E55. If there is a genuine problem it needs a genuine fix.
