What can the 5.5 really do?
Originally Posted by medici78
Marcus, I've noticed you are concerned with the transmission's power handling. However, I've read that this is the same unit that is used in the V12 M-B's, which have mountains of torque and there's several Renntech cars that are holding up, as well as the 996TT Tiptronic. The Porsche tuners I've called agree that the tranny can hold up to a lot of abuse as they have thrown more and more power at it, and it still holds up.
I think at 130mph we'll be at the limit for our drivetrains, realistically. I know DerekFSU is there now but he's already he said "he doesn't give a F if it blows up" while I think the rest of us do. 130mph is FLYING and right there in Enzo/CGT territory so it's really nothing to scoff at.
Again, I know our trannies aren't weak, but to get a 4000lb car to run 130mph traps is just insane on a production drivetrain.
-m
So what is the formula to get an 11.5 sec car?
-Weight reduction (You can get this car down to 3850 without any compromise to luxury)
-Wheels -40
-Brakes -34
-Light weight battery -40
-Remove Spare -50? (I have not weighed the spare, just a guess)
-Remove under hood insulation (It can and should be done, it will not compromise the paint) -5-10
-Boost (Marcus, how much can this blower put out?)
-Transmission (It will hold for this trap easily)
-Heat Reduction (FMIC or TMIC)
Then we go for the 10's
-Wheels -40
-Brakes -34
If we had a CF hood that would take away more weight from our E55 sled. By the way I think we would be VERY hard pressed to knock off 40lbs off the wheels unless you stuck with a 19-20lb rim and stayed with an 18 in. Btw, what out there looks half decent and weights under 20lbs?
This is how I knocked out 225 lbs from my S4 Audi. I was about to go with 18lb seats but then it would have lost its luxo audi feel.
- 25lbs exhaust system incl DPs
- 50 between tires and rims (18 inch SSR comps @16.5 lbs each)
- 25 brakes
- 40 light battery
- 25 CF hood
- 40 battery
- 10 misc crap
- 20 lightened flywheel
+10 FMIC
- 25 brakes
- 40 light battery
- 25 CF hood
- 40 battery
- 10 misc crap
+10 FMIC
