SLR 5.5 vs. E55 5.5
Old Oct 4, 2005 | 10:46 PM
E552006's Avatar
2020 G550
SLR 5.5 vs. E55 5.5
What is the difference between the two engines other than IC system?
Different internals?
Blower?
Old Oct 4, 2005 | 10:56 PM
vraa's Avatar
I know it's got reinforced and lighter internals.
That's all I could find through a quick google.
Old Oct 5, 2005 | 12:16 AM
BoBcanada's Avatar
AMG
i say we research and then remake E55 engines into SLR's ones.
Old Oct 5, 2005 | 01:07 AM
MB Fanatic's Avatar
4 wheels
If you fund the research ill be the first to line up.
Old Oct 5, 2005 | 01:25 AM
Bigdot's Avatar
some
well for one,
arnt the S/C AMG 55s 5.4L V8s
and the SLR is 5.5, so there is 10 of the 130 less hp, lol
Mark
Old Oct 5, 2005 | 06:25 AM
tommaey's Avatar
2012 C63 Coupe Iridium Silver
are you sure that the SLR engine is 5.5L?
So many reliable resources claim the 55s are 5.5L V8s when they're obviously (or not) not
Old Oct 5, 2005 | 08:36 AM
E552006's Avatar
2020 G550
According to MB they are. Go to mbusa.com and look at the SLR literature.
Old Oct 5, 2005 | 09:05 AM
TECHNICIAN's Avatar
S 63 Coupe, GLS 63
SLR has a m155 engine. E55 is a m113 engine.
slr is dry sump
supercharger has external oil supply
multi piece crankcase
heads are the same, except valve train
Old Oct 5, 2005 | 12:31 PM
E552006's Avatar
2020 G550
slr is dry sump
Same rods and pistons??
Are there any flow advantages given by the valve train?
Otherwise this would indicate that the m113 engine can flow enough air with stock heads to achieve the same power levels.
Old Oct 5, 2005 | 04:19 PM
E552006's Avatar
2020 G550
Did some research
SLR
ENGINE
Type: supercharged and intercooled V-8, aluminum block and heads
Bore x stroke: 3.82 x 3.62 in, 97.0 x 92.0mm
Displacement: 332 cu in, 5439cc
Compression ratio: 8.8:1
Fuel-delivery system: port injection
Supercharger: twin-screw Lysholm
Maximum boost pressure: 13.1 psi
Valve gear: chain-driven single overhead cams, 3 valves per cylinder, hydraulic lifters
Power (SAE net): 617 bhp @ 6500 rpm
Torque (SAE net): 575 lb-ft @ 3250 rpm
Redline: 7000 rpm
E55
ENGINE
Compression ratio: 9.0:1
Supercharger: ??
Maximum boost pressure: ??
Valve gear: ??
Power (SAE net): 469 bhp @ 6100 rpm
Torque (SAE net): 516 lb-ft @ 2650 rpm
Redline: ? rpm
Not sure if the Blower is exactly the same, anyone know?
Old Oct 5, 2005 | 04:55 PM
MB Fanatic's Avatar
4 wheels
Our E55's have a Lysholm twin screw supercharger.
Old Oct 5, 2005 | 05:12 PM
E552006's Avatar
2020 G550
Same specs? Flow rate?
Old Oct 5, 2005 | 05:13 PM
MB Fanatic's Avatar
4 wheels
I think the supercharger is the same basic setup but is more powerful in the SLR. The SLR also has a far more efficient cooling system than our E's do.
Old Oct 5, 2005 | 05:14 PM
BoBcanada's Avatar
AMG
Whats SLR weight?
Old Oct 5, 2005 | 05:16 PM
Vadim @ evosport's Avatar
C32 AMG
From performance standpoint - SLR over 55s:
1. Dry sump lubrication (could be worth 20-25HP)
2. 1.5 lbs. of additional boost (15-20 HP)
3. Dual, external intercoolers (30-40 HP)
3. Equal-Length Headers (30-35HP)
4. No exhaust (just mufflers with cats) (10-15HP)
5. More agressive DME tuning for a lighter car (15-20HP)
Here is a picture of an SLR engine:
Old Oct 5, 2005 | 05:20 PM
AMGcrazy's Avatar
2008 E63
Vadim,
Not a challenge, but a question: How does dry sump lubrication give you added HP?
Everything else makes perfect sense.
Old Oct 5, 2005 | 05:25 PM
C32 AMG
AMGcrazy: No problem. Dry sump removes windage losses due to crank spinning in oil at the bottom of the sump. There are also additional benefits from more efficient lubrication and oil temperature control.
Old Oct 5, 2005 | 05:26 PM
AMG&AMG's Avatar
AMG
Originally Posted by E552006
Did some research
SLR
ENGINE
Redline: 7000 rpm
E55
ENGINE
Supercharger: ??
Valve gear: ??
Redline: ? rpm
even the SLK 55 has the same engine block
Old Oct 5, 2005 | 06:06 PM
E552006's Avatar
2020 G550
Whats SLR weight?
Weight is about 3750 or about 300 lbs lighter than an E55.
Old Oct 5, 2005 | 06:08 PM
E552006's Avatar
2020 G550
Thanks for the response.
So you are saying there are no differences btw the internals other than lowered compression (head gasket change I would assume).
BTW
Any progress on an air-air intercooler for our E's?
Old Oct 6, 2005 | 04:13 PM
TECHNICIAN's Avatar
S 63 Coupe, GLS 63
No it doesn't. The M155 in the SLR is split at the main bearings. Its a 2 piece crankcase. The ONLY benz with this type of block. Much like the new v10 in the M5.
Old Oct 6, 2005 | 05:49 PM
C32 AMG
BTW
It might have stronger pistons, that's still needs to be confirmed.
As far as intercooling, we are working on SLR style upgrade, first drawings are going to machine shop on Monday.
Old Oct 7, 2005 | 04:49 PM
E552006's Avatar
2020 G550
Sweet!!!
Can't wait to see the results of this.
Please post updates on the forum.
