E55 swap into a C230?
Old Nov 3, 2005 | 11:34 AM
Marc's Avatar
Originally Posted by MB Fanatic
Best of luck, but this is going to be one time consuming, laborious investment. Though I still don't see the logic or train of though here, I wish you the best of luck.
The logic or train of thought is building a C230 sleeper that is considerably lighter and faster than the E55 -- for half the price.
Old Nov 3, 2005 | 11:36 AM
Marc's Avatar
Originally Posted by G55K
Marc,
It is possible. Kleemann in Colorado was going to do this exact same swap with a C320 4-matic. They put the project on the back burner becasue they've been so busy. The only hiccup they ran into had to do with the ECU. The price of the swap was much lower than everyone posting thinks. Send Kleemann an E-Mail and maybe they'll give you some guidance. Good luck!
Yep, the electronics seem to be the biggest challenge at this point. Lucky for me I have a few friends that work for MB in Montvale, NJ who will be assisting with the swap.
Old Nov 3, 2005 | 11:42 AM
G55K's Avatar
I'm looking forward to the results!
Old Nov 3, 2005 | 01:43 PM
amgdriven's Avatar
w210 E55
It sounds like it will be awesome! :v
Take pictures as you install...........keep us informed!
Old Jul 20, 2024 | 08:40 AM
DookiesC230's Avatar
C230
Results?
I was looking into doing the same thing to my c230 did this work??
Old Jul 20, 2024 | 11:07 AM
Marc's Avatar
Yes, it did but it was a pretty big project. Took us three nights in the workshop. But the result was well worth it. I still daily drive this car. 386K miles on the original engine and trans! Still going strong!
Old Dec 30, 2024 | 11:27 PM
  #32
KyleCalderon04's Avatar
Question
Just curious, how difficult a swap would it be to put an 03 E55 AMG engine/supercharger/trans/rear end/etc. into a 2003 C230? Would any fabrication be needed or would it pretty much bolt in with all the right parts? Thanx for any info!
i would like to know if you ended up doing the Project and how it turned out.
Old Dec 31, 2024 | 02:45 PM
  #33
cdk4219's Avatar
95 SL600
It can be done, but there’s a reason that the c55 front end is different, it needs to be longer for the V8, then there is the differential and brakes and fuel pump, as well as coding and many other things. I figured it would run about $9000 to put one in a c55 and probably $14,000 in a c230 if I did the work myself, and that’s probably on the low end.
