M5 weighed on M% forum
Check it out.
Looks like BMW under reported the weight of the new 5
http://www.m5board.com/vbulletin/showthread.php?t=61701
Hmmm looks like it weighs as much or more than the E55.
If I did my math right (which I probably didn't) it's around a 5% difference.
Is that really a big deal?
Has anyone weighed their E55's? I want to compare with numbers in the brochure/manual. This might be interesting.
So uh, are most weight numbers kinda balony unless the cars are tested at the same time and what not?
Originally Posted by Grumpy666
If the weighing conditions are standardized (ie, the same) wrt fluid levels, etc, and the scales are properly calibrated, then the weight numbers should be valid. If someone want to pick nits, then theoretically, altitude is also factor, but at 5000 ft vs 0 ft, it's less than 0.5 %.
