Old Jun 9, 2015, 04:09 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: General Overview
Print Wikipost
Jacking up E55?
Old Dec 1, 2005 | 05:29 PM
WayneE's Avatar
'72 Suburban
Jacking up E55?
Where are the lift points in the rear to jack up the E55? Can I jack right at the pumpkin? I'm going to be bringing a jack and tools to swap tires at the track tomorrow and would like to know a safe place to lift the car.
Thanks!
Old Dec 1, 2005 | 05:38 PM
xraymd's Avatar
2008 335 vert, 2004 MDX
I changed to winter wheels/tires two weeks ago. I just looked and felt underneath the car and they were pretty easy to find. Just feel for the gap in the plastic.
Old Dec 1, 2005 | 06:16 PM
rflow306's Avatar
2005 E 55
Thanks!
Yeah
Wayne that is the best way to do it just place a towel over the jack so you don't scratch the heat fins under the pumpkin. With the factory jack you can only change one wheel at a time. The lifting points have square boxes to receive the factory jack they are located behind the front fender and in front of the rear fender. Hope this helps -Albert.
Old Dec 1, 2005 | 06:24 PM
xraymd's Avatar
Not to sound like a dufus, but what's the pumpkin? Is that the differential?
I jacked at the jack points, but I used a floor jack. I didn't want to get my factory jack all dirty
Old Dec 1, 2005 | 06:39 PM
Christanza's Avatar
2002 996 C4S
Erm, I would also like to know what this pumpkin thing is....
Old Dec 1, 2005 | 06:40 PM
rflow306's Avatar
2005 E 55
Yes the differential , pumpkin is the muscle car term for it.
Old Dec 1, 2005 | 07:02 PM
WayneE's Avatar
'72 Suburban
I have a big aluminum jack that I'm bringing to the track, so I'll bring a towel and jack right up at the diff (yes, the pumpkin ).
Thanks, guys!
Old Dec 1, 2005 | 08:07 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Maybe someone else could chime in, but that scares the crap outta me.
These rears are a lot different than the old fashioned boat anchor posi units that you could basically balance the entire car on.
You think it could damage it? It is a 2 ton tank...
Just curious as to why you wouldn't just jack her on the jack points near each wheel on the sides. You just wanna nail um both at once??
Old Dec 1, 2005 | 08:15 PM
AmenMercedesGo's Avatar
2005 E55
Jack it from the points in front of each rear tire with the stock jack. The points are square holes that can be seen and felt about 8-10 inch in front of the rear fender wells. Remember to break the wheel bolts loose first then jack it up and make sure the emergency brake is on!!!! Re-torque after letting the car back down.
Old Dec 1, 2005 | 08:44 PM
WayneE's Avatar
'72 Suburban
Cordless impact and my 1/2" torque wrench. No worries.
I looked under the car and my portable, aluminum jack will work great with the stock lift points in front of the rear tires.
Old Dec 1, 2005 | 09:07 PM
Vetluver's Avatar
SL 65 AMG and E63s AMG
I know you prolly know this but just in case, be sure to lube the lugs before torqueing them. Does anyone know how tight to torque them to? My Vette is torqued to 100ft-lbs.
Old Dec 1, 2005 | 10:42 PM
DJE55's Avatar
07 S65
Wayne, what tires did you get? I hope we are still running tomorrow. It's was snowing at my house about 30 minutes ago.
Old Dec 1, 2005 | 11:33 PM
04E55 AMG's Avatar
04E55AMG, 05Dodge RAM 1500 Quad Cab, 02Montero Limited
Everything has cleared out. Will be sunny and mid 40's in the am. I will call you when I get to Mike's.
Old Dec 1, 2005 | 11:47 PM
xraymd's Avatar
Owner's manual says 96 lb/ft or 130Nm.
Old Dec 2, 2005 | 07:37 AM
WayneE's Avatar
'72 Suburban
No tires for me, I'm bringing tools along to swap Spero's for him.
