RECIPE FOR 10sec BENZ
..........now that a few folks are running in the low to mid 11's, what do you think is a recipe to get into the 10's without nitrous? I post this on this forum because the E55 folks seem to modify their cars more often, but the question is not limited to E55. I'm very interested in this.
Ted
Ted
Just no way in my opinion without major engine modding.
I say the only way is the Brabus method.....yanking the motor and start-a-borin.
Ted
The Kleemann SLK55 K8 would be interesting. Or find a way to lose 300kg on a stage 2/3 E55 and it might be possible. A good start would be a CF bonnet + boot, losing the passenger seat and replacing the drivers seat with a racing one for about 100kg weight loss. Then change battery and remove spare tyre for another 40kg. Fabricate a full titanium exhaust system, change rear wheels to 17" ultra lightweight ones and use Evosport rotors for another 50kg. After that it would get more complicated, hardcore stuff like getting lightweight glass for the windows/windscreens and removing the sound deadening material ... etc. But with the kind of weight our AMGs are having, its never going to be easy. You're looking at either really big power or going on a severe diet.
If you take a car like Derrick's (DJ) at 11.52 in the 1/4...
- looser converter (even just 1000 rpm would be a huge difference)
- steeper rear gears
- taller, stickier rear tires
You'd be running 11.05-11.15s in the 1/4. I don't think any of those things would compromise the daily drivability of the car like severe weight savings, etc.
Slap the car on a dyno and tune it on 100-103 unleaded and you'd have a 10 second car.
Derrick ran a 1.7 short on his 11.52 pass.
So just tires/converter should net a 1.5 on a good track. That's .20 in the first 60', which generally equates to .30 at the big end of the track. So theoretically speaking, that COULD be a 11.22 with just those 2 mods. Add in gears and I think my estimates are pretty close.
That said, I don't think anyone knows these 3 things...
- will the tranny survive that abuse?
- will the ECU freak out with a looser converter? will it think the tranny is slipping?
- will the rear end and/or 1/2 shafts survive?
How much more boost will our stock blowers produce?
Originally Posted by DerekFSU
I hope so but I just don't think tires, gears, and a looser converter is going to net over one half of a second.
Originally Posted by Beowulf
I've seen a 3600 stall converter + ET Drags net better than a half-second improvement over bone-stock times, but we're talking a GM 4L60E tranny on an LS1 F-Body, not an MB AMG 5-speed. Does anyone make a high stall converter for the AMG 5sp?
My friend's 96 TA, which is only 250lbs lighter, runs 1.3s. 9.5s in the 1/4.
You can see it on next season's first episode of Pink's.
My point being that it can be done. It's just that the durability of the MB drivetrain that would be the issue I've seen a handful of 1.64-1.68 60' times at our track days out of E55s, so it's not like we're talking about going from 2.00s.
<<Slap the car on a dyno and tune it on 100-103 unleaded and you'd have a 10 second car.
Wayne,
Where around MD/NOVA can you get 100-103 unleaded. I can only find 114/116 leaded which obviously won't work.
Also does ANY one on this board other than the dude that ran high 11s in a W210 have any experience on going with 282 or 307 gears? I wonder how much that would help using of course drag radials...perhaps launch from 2nd gear and hope you make up time with one less shift?
Wayne,
There are 2 stations in Damascus that sell it at the pump. Main Street is one (they have a shop/dyno there, too) and the other one is only a couple 100 ft away. Main Street sells VP and the other place has a pump for CAM2.
And with steeper gears, you'd negate the gains by launching in a higher gear. Launch in first on a sticky tire and hang on
04E55AMG, 05Dodge RAM 1500 Quad Cab, 02Montero Limited
Wayne,
Wayne,
Issac,
Since you are in VA try Winning Edge Performance in Manassas. I have purchased Sunoco GT 100 Race Fuel from him several times.
Call 703.369.3499 and ask for Mike (he is the owner). Tell him I referred you.
9108 Euclid Ave
Manassas, VA 20111
www.winningedgeperformance.net
Spero -- thx so much. I am going to go and fill up and get bring a few extra 5 gal cans. Is it pump it yourself or is it all in drums.
Btw, was looking at the Supraforums and a stall converter would be the ticket...stock twin turbo supras putting down 400-500rwhp at 3600lbs trapping 117-119 are running 10.9-11.3s with a 3800 stall. Someone has to make one for us. Your 1.6x short times will be 1.4x
http://www.supraforums.com/forum/sho...d.php?t=282839
Auto
1. 10.979@121.39 Amar - BL tranny, 3,800 PI stall, 75 shot, and BPU+.
2. 11.067@117.68 HotSoup
3. 11.12@121.98 1.555 60ft Erik Doer Sport Compact Pro Oct 2004 at Cecil County Dragway in MD
built Boost Logic auto 3900 stall
bpu ++ 18 inch drag radials
stock twins,stock fuel system, motor, and intake manifold. NO NOS
Auto
Auto
Auto
Make sure you call him before going since he has shorten hours during the winter.
2008 Bentley GTC, Porsche GT2/EVOMS GT700, 1968 Dodge Charger Hemi
No, I just happen to know my own times. My best 60' on OEM rims with BF DR's was 1.74. My best 60' with the CCW's and MT SR's was 1.698. So if just wheels and tires will put you in the 10's, when you doing it? I'm tired of waiting on you V-12 TT boys to sack up and take the title.
Even though you only got a 60' of .05 faster, I think the lighter, smaller wheels helped you on your ET and trap speed.
Originally Posted by RennTechV12
I can't say for sure it will, I'm just going by what my tuner's computer says. I got the 11.43 with a 60' of 1.795. I'm having them measure for the wheels this week. We're still not sure if the calipers will clear. I will post when I find out more. Our Elevation, relative humidity, temp and barometer kill us here in AZ.
I ran DR's for the first time in my life last week on 17" rims (BBS RC - 20 pounds) and BF DR's(275/40/17) and I was getting in the 1.6 range all day with 1.64 being my best 0-60' time.
DR's ROCK
