Video of Spero's burnout and others
I realized that on a regular street, even 1600 is too much because it just burns rubber.
If not how did you spin the rear wheels without the fronts moving at all?
- get a little water on the rears
- pull up where it's dry in the burnout area (usually just a few ft)
- apply just enough brake to keep the car from rolling
- aggressively get into the gas while feeding in just enough brake to keep the car from moving... hold at a steady rpm
- when the tires begin to heat up, they will drag the revs down just a little
- left off the brake and then the gas
Do you need to do this in Dyno mode or can it be done with just TC off?
Do it with TC off then put it back on when you stage.
Yes, Spero had drag radials on his car.
During your burnout, you don't need to hit full throttle. You need to get the tires spinning quickly and then keep them spinning. The faster they're spinning, the less time you have to heat them up. As the tires heat up, they will get sticky and it will become more difficult to spin them. This will start to drag the motor down a little and this is when you stop doing your burnout and roll up to the line. 2-4 seconds is usually plenty of time.
2 things with Spero's runs:
1. These were brand new tires. New tires will require a bit more time burning them for the 1-2 passes.
2. It was COLD. The track was very cold and so were the tires.
If you're racing at the track, try to avoid driving through the waterbox. Drive AROUND it and then back in. If you drive through the waterbox, you will track water up to the line and reduce your traction (we had Spero drive through because we were controlling the amount of water in the box). If you're on street tires, you don't need water at all, just a quick burnout to clean off the tires is all that is necessary.
