Anyone know what this code means?
1 Post
2007 M5, 2004 X3 3.0i
Star diag last time my car was in came up with code P202C. This was causing a check engine light and they had already previously changed the coolant thermostat. This time they said they changed the coolant temp sensor, which sounds more of the same, but thats not whats bothering me.
What does the code mean and are they looking in the right place?
P202 is the fuel injector # 2 circuit. It could be loose, shorted, open or bad injector..
If the coolant temp sensor went out all the way, it could have had the injector pumping full blast all the time and messed it up?? Just maybe?? Or the tech accidentally messed up the #2 circuit while replacing the temp sensor..
Good luck
Good luck
