Rev Limiter
My car does go over 6,000RPM before it shifts, but, I guess the shift point would depend on what your ECU was programmed for as the soft limiter point. My car's rev limiter was programmed as 6,500RPM I believe. You should check with Kleemann and see what they set the rev limit to.
The cellar we had built will hold about 800 bottles. I used a ChillR unit for cooling. You just need a sealed room and the ChillR units can be mounted above the door. Nothing huge, but it will hold plenty of wine for us
I'll PM you about Laurel
How's the new place?
Here is part of my wine cellar at home.. All custom racking... I bottle my own and also purchase certain select vintages.
This was taken shortly after the installation was complete.. 600 bottle capacity on all the racks combined.
The bottles are slightly tilted downward. The corks are wet. Temp is controlled at 15C and humidity at 65%.
