Best Data Logger for E55
Old Jul 23, 2006 | 10:57 AM
DFW01E55's Avatar
'14 ML BT
Tried the scan tool at Ennis on Friday night. I only measured intake temp, rpm's, speed and coolant temp in order to keep the fastest sampling rate possible.
Unfortunately, each pass down the track, the tool or engine data output went into brain lock and there was no data shown from take off until deceleration.
So I know that my intake temp went from 162 (95 degrees at 8pm) to 235 in 14 seconds but there's nothing in between.
I've sent a detailed e-mail to Auto-Enginuity, we'll see what they say.
Old Jul 23, 2006 | 12:50 PM
SLK55R's Avatar
'10 Porsche Turbo PDK, 500e, GL450
hrmm
My scanguage tool has it on fast and I see only a delay of about 1 sec.
Old Jul 23, 2006 | 02:24 PM
DFW01E55's Avatar
'14 ML BT
That's interesting, here's a snippet of the response from Autoenginuity:
When your vehicle goes WOT throttle it shuts down the unnecessary tasks down. The only way around it is to never go WOT throttle so the ECM won't switch the DLC off.
Shocker! They blamed MB!
Jesseliu, what brand do use and have you used it at the strip and only experienced a 1 second delay?
Old Jul 23, 2006 | 02:45 PM
rflow306's Avatar
2005 E 55
I have the auto-enginuity also but i can record the entire run from burn-out to shutdown with out a problem. Are you using the blue-tooth or the usb connector.
vrus's Avatar
2003 E55 AMG
That's NOT true! I've done many a datalog on Autotap at WOT and it works just fine. Problem has always been the sampling rate. OBDII just doesnt provide enough to get very fast sampling. I get only a few records of data but it does show the info.. Also, I can see the values changing in the graphs & charts as the car accelerates.
Old Jul 23, 2006 | 03:03 PM
DFW01E55's Avatar
'14 ML BT
USB connection, KWP2000 interface, OBD-II compliant initialization, Fast Mode and heartbeat checked.
Old Jul 24, 2006 | 05:57 AM
  #32
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
The seriel version is suppossed to be quicker in some modes I read somewhere ...
Old Apr 27, 2009 | 10:21 PM
  #33
TexasSteele's Avatar
2005 e55AMG
So 3 years ago it seems auto enginuity was the best out there...has anything changed?
Looking to log my analog wideband output as well...
Thanks!
Old Jun 17, 2009 | 11:53 PM
  #34
FLSL55's Avatar
SL65
PC-based solutions
- Autotap http://www.autotap.com/productcat.asp?topLevelid=36
- AutoEnginuity http://www.autoenginuity.com/products.html
- Ease http://www.obd2.com/scantool/scantool.htm
Standalone device options
- Race-Technology DL1 http://www.race-technology.com/data_loggers_8_920.html
- Car Chip http://www.carchip.com/
- Scan Gauge II http://www.scangauge.com/
Or... This one http://www.harborfreight.com/cpi/cta...emnumber=99722
Old Jun 18, 2009 | 12:04 AM
  #35
bassn_07's Avatar
2006 E55 AMG
I use dashdaq with Innovative Motorsport's wideband. Actually the wideband isn't hooked up yet becasue I forgot it in LA.
http://www.innovatemotorsports.com/x...cat=265&page=1
