After all that talk about lowering I measured my car's hight.
It sits lower on the front left than right corner and lower on the right rear than left corner.
How can that happen? Can the dealer fix it easily?
It's pretty common on these cars with the active suspension. First check all of you tires and make sure the tire pressure is the same. If they are, take it into the dealer and they can adjust the suspension.
Mine varies in absolute height and side to side frequently.Originally Posted by BlackBear
After all that talk about lowering I measured my car's hight.It sits lower on the front left than right corner and lower on the right rear than left corner.
Go measure it again - it will probably be different again.
