Motor Trend CLS55 vs. M5 (March 2006)
#51
Originally Posted by jordan
Help me out...if the M5 is faster to 100 mph how can the CLS be faster in the 1/4 mile. Did it speed up and slow down from 100 mph-113.6 mph. It looks like the M should be faster in the 1/4 as it is going faster at 100mph. Sketchy testing.........
M5 is faster in reaching 100 mph. CLS is slower in reaching 100 mph.
However acceleration through that time frame is not a constant.
CLS launches better than M5 and accelerate better from 0-60. Thus is put more distance between M5 and CLS. M5 starts to catch up from 60 mph to 100 mph. M5 was simply not able to recover from poor launch it has in time when it passed 100 mph. Even though it hit 100 mph faster than CLS, but due to lousy launch capabilities the distance that CLS put on the M5 at 0-60 is probably quiet big (probably at least 1 car length ahead).
#52
Originally Posted by Jakpro1
Only 1 CLS on dragtimes and she comes in at 12.3.
That's pretty hot, but here is the catcher....60' time....2.0!!!!
That means he just hammered it off the line and ran 12.3. Imagine if he got a good launch....with a 1.7-1.8 60', who knows what that thing would have run bone stock.
http://www.dragtimes.com/Mercedes-Be...slip-5559.html
#53
2010 ZR1 2011 JGC Overland 2013 ML63 on order
Originally Posted by MG0427
so what are the dyno results?
https://mbworld.org/forums/w211-amg/133882-kleemann-k2-installation-begins.html
#54
2005 Brilliant Silver E55
Originally Posted by rvmasi
If you only look at the 0-100mph time, these are two well-matched autos. In the 0-150mph run, the M5 is several seconds quicker. At 150mph, you're traveling at about 220 ft per second. I believe the difference was about 4 seconds (can't recall exactly). So, this suggests that the M5 at 150mph was 880 ft ahead of the CLS. That translates to about 55 car lengths. Holly moley!
#55
13 SL63
Originally Posted by MB_Steve
Why is it than that the latest edition of Road & Track shows the weight of the CLS 55 at 4307 pounds. January 2006 Car & Driver lists the CLS weight as 4324. This compares to The January 2004 Motor Trend showing the E55 weighing in at 3857 pounds and the December 2004 Motor Trend showing the E55 weighing in at 4100 pounds. Seems like a wide difference if you ask me. No where have I read that the E55 weighs more than 4100 pounds.
The CLS 55 (despite MB's claim it is a coupe) is a bigger car. Look at the stats:
..................E55...................CLS55
Length, in.....190.9..................193.5
Width............71.3....................73.7
Height...........57.0....................54.7
CLS is 2.6 inches longer, 2.4 inches wider, while the E55 is 2.3 inches taller. Sounds like the CLS is a bigger car to me. How could it weigh less? I don't believe MBUSA's website.
The weight of each car is going to be different depending on options. The 3800lb weight was the intitial # when the e55 was first being introduced. Due to US regs. the car gained weight ie additional safety equipment, smog related junk. Also i know for a fact that my panarama roof added 200+lbs to the car. Thats how we have varing opinions on the weights of these cars. Btw both are great sports sedans but neither is a sports car.
#56
1 Post
'10 Panamera S, '06 AMG CLS55, '07 Miata MX5, '02 MB SPRINTER, '99 Spec Miata Race Car (2X)
Hi guys
just wading into this E55 vs CLS55 vs M5 discussion
Yup Fikse's dragtimes.com website shows how many E55's are running really fast 1/4 mile times, but there are several 1000 E55's out there, and guys have been improving their times over the three years it has been out. It took me a year to drop from 12.5 to 12.169. Waiting for the right weather conditions to align with free time between business commitments, all these things explain why you dont immediately see fast times appear immediately after a car is released, and why tne times get better with time. (huh?)
The CLS55 is very new to the market - there are very few in the country (only 1250 manufactured worldwide per annum vs. 2250 E55's each year iirc).
As more CLS55s hit the strip we will see similar times the the E55's. And the same thing is going to happen with the M5's as well, despite their lack of launch contol in the US. They too will get it wired, learn how to launch and we will see quicker times being posted to the site.
And with regard to overall performance I have raced both at three AMG challenges during 2005. The CLS seemed to be tighter when turning in (could be purely the stiffer ride of the 19's who knows), but the performance of both cars was almost identical. I swapped out between teh CLS55 adn E55 at every opportunity and could not determine that one was definitively faster than the other.
I am hoping that the LSD on my CLS55 with 030 will be worth something. Time will tell - will be at Moroso as soon as time and weather play together.....
#57
#58
Originally Posted by ricky.agrawal
From what I know, the CLS55 has a different steering rack than the E55, hence the quicker turn in.
#59
Originally Posted by Grumpy666
The steering ratio has nothing to do with turn-in response. This is modulated primarily by the suspension. It's a measure of how quickly the car tracks to where it's pointed.
Then what use is the steering racks ratio anyways? Is it just sensitivity? From my understanding it's how many turns from lock to lock right?
#60
'10 MB E63, '08 ML550 ('05 E55, '05 SL55, '08 E63 GONE)
I disagree the cls55 is more aerodynamic, I have friend that has e55, and next to each other, the cls55 is sleek more rounded and lower (cls55 height 54.7, e55 57.2 per mbusa.com, why would they lie about weight & other figures), the e55 is built a family seden platform.
It's not about sleek looking or rounded... it's how air flows around, over, and under a car. Until you get to insane aircraft speeds looks don't tell the story.
That said, it probably doesn't matter. Weight is much more a factor when comparing these two cars.
~ Ian
#61
#62
Thanks for the correction.
#64
Originally Posted by AMG&AMG
is it true that the cls is based on the E or C chassis? more like the C class?
I heard it from a salesguy though,,,
LOL..
those sales people!
E-class chassis... 100%
#65
E55
Originally Posted by Ted Baldwin
..............I have had a deposit on a CLS65 for almost 2 years now, ever since I heard the first rumor about the car. The last info I heard was that the car will not be made. Is your information more current? I hope this is true.
Ted
Ted
#66
'14 428i M-Sport, '02 C32 AMG
it's no surprise the CLS55 won in acceleration to the quarter mile. it should also be no surprise that the e60 m5 should win on the top end, from a roll. if the race was 1 mile, the m5 should be ahead. gearing, engine configuration, and the nature of the power curves indicate this. i'd like to see a CLS55 with mkb differential / shorter gearing. it should liven up some top end acceleration.
me, personally, i'd rather have the cls55 - exhaust note, responsiveness to modifications, and style. the cls55 would be a perfect complement to a porsche gt3. the m5 is a fantastic car, i like to think it's a relatively good compromise of both, with fantastic top end acceleration. if only the maserati quattroporte had more grunt...
#67
#68
#69
Originally Posted by TopGun32
we have yet to see an CLS55 hit low 12's... on a 1/4 mile..
We have seen a bunch of E55's be around 12.1 to 12.2 and some as low as 12.0x..
of course altitude, weather, humidity all play a factor and depending on where you live, but to this date most CLS55 run 12.5+
by the way, it looks like Motortrend tested in bad weather or poor track conditions, since 12.7 for a 55k motor seems a bit high
That's why I place little faith in magazine tests. They are interesting, of course. But show me time slips from a drag strip, and I will take those over any magazine test.
Have yet to see a magazine get lower than a 12.4 for an E55. I consider a 12.4 to be dissappointing when I hit the track.
#70
So now imagine the M5 being 85 ft. (5 and 1/2 car lengths) behind an E55 and racing from 117 mph (average speed of the two cars - the speed difference is negligible) to 150 mph. That's a 33 mph gap. I can't see how the M5 picks up 60 car lengths (965 feet) to finish 880 feet ahead with only 33 mph to pick up. The M5 is very fast at high speeds, and it will get to 150 mph in lesser time, but I don't believe that it could create that kind of distance.
Am I missing something?
#71
Originally Posted by IanSL55
SHOCKER: The E55 is more aerodynamic than the SL55.
~ Ian
~ Ian
internal air passages could also effect the drag - you really need to get the CFD and wind tunnel reports to see the air paths thru and under the car.
in other words, looks of a car and it's aerodynamics can be quite different.
#72
540 6spd
Just to throw a little kink in this arguement over power to weight ratio's between the CLS and E55 think about this. A E55 wagon which weights more than both, but has most of the additional weight in its rump runs 0- 60 in 4.1 and the q/m ini 12.4.
#73
#74
Weight balance is alot of handling...and traction.
The E55T hooks up better simply because of the extra weight over the rear tires. If one didn't mind the extra weight in the car, the old pickup truck in the snow trick of adding a couple of bags of kitty litter, sand, or cement mix, etc. in the trunk next to the wheel wells should do the same for an E55 sedan....100#? 150#?
I am actually surprised that the draggers amongst us having tried or experimented with this themselves and posted about it......
#75
Originally Posted by ClayJ
. . . the old pickup truck in the snow trick of adding a couple of bags of kitty litter, sand, or cement mix, etc. in the trunk next to the wheel wells should do the same for an E55 sedan....100#? 150#?
