Cold Air Intakes
Pls PM me if you can help or know someone that can.That's your coolant temp unrelated to air temp. Put some water wetter into the
radiator. My coolant temp is below 90 at all times.
I'm on it. I don't even care if it helps much. It is cheap, easy, and great in theory!!
Anyone try the ceramic spray on the plastic parts first?? I may add that in!
I also got a set of stockings and whip for myself
I'll try to post some pics later.
I'll try to post some pics later.I tried to buy the stainless foot rest but can't! It is glued to the carpet, can you believe this BS?
1) can i do this myslef
2) If I have a carbon fiber airbox, do you think it also needs to be wrapped. Doesn't carbon fiber transmit less heat.
I am going to get my air intake tubes thermal covered this weekend. Question...IF I have a carbon fiber air box, do I need to get it covered as well. Does the carbon fiber insulate the box from heat?
https://mbworld.org/forums/w211-amg/145853-air-tube-temperature-recordings-results.html
My personal view is that wrapping the airboxes is a waste of time and money.
Do you still have this view after reading OZE55's test..
Saber,
How about you? Did you really see a noticeable difference from insulating your air intake?
I have Renntech headers that are not coated? My air intake tubes must be blazing hot when I am running my car.. I think thermo coating might work. We will see as I plan to dyno test before and after..If anything, I think it is the airbox that is the most important to insulate.
