Anyone try retro park distance control installation?
if so, what's involved in the process? must you replace the entire $1,300 rear bumper? i regret not getting it. i've already bumped into 3 pillars.
W203 slightly modified
Mercedes C43 AMG
retrofit parktronic
Does anyone know how much it is to retrofit the parktronic? what is involved? I need to get it installed on a E63 wagon.
Thanks,
Baron
Thanks,
Baron
Mercedes C43 AMG
'09 911 C4S
Dealer is not likely to do it. Since you're in the bay area, you should contact Scorchie (aka Dean) on this board. He should be able to help even though he seems to be MIA at the moment.
1 Post
06 E55, 03FORD P/S,01 E320-4M,99 ML320,O4 E55,05 RUBICON UNLIMITED,
Another Option Is To Go See Your Local Higher End Stereo Shops, They Have Aftermarket Sensors That Can Be Color Matched And Look Factory. You Just Don't Get The Lights, But They Could Be Added. They Mostly Only Do The Rear Only Since They Can Wire It Off The Reverse Lights, The Front Are Speed Dependent From The Factory. If You're In The Bay Area Let Me Know I Can Find You A Good Shop.
Mercedes C43 AMG
Thanks for everyone's help.
I contacted Steve on this board and he said it is hard to do on the 07 W211s. Apparently there are no more strips you could take out. I would have to replace the entire bumper, front and rear.
I am fine with just adding the parktronic to the rear, and don't really need the lights. The beeping sound is sufficient.
2015 S212
Contact Steve @ MBenzNL if Dean is missing.
