New shoes and some mods...
2017 S63 Coupe Iridium Silver
Originally Posted by Rafal
CLS55 E25 Front and E28 Rear. If he lowers the car or corners hard, they will rub, for sure, at the point where the bumper plastic meets the rear fender.
Originally Posted by M5 RUS
Man...How don you know everyhing about this staff...
So my UL's with 285/30 19 with ET33 will rub like this as well or not necessarily ???
I work on my cars myself and don't trust anybody, especially those who take my money, only to lose interest once things start going wrong. I drive dealers crazy, it's a desease!
No it is not! It rubs only at the trailing edge of the rear fender, where the rolled metal meets the sharp molded plastic bumper. It is that sharp plastic edge that will gouge your tire. You can file it off, but then your bumper will fall off...
Originally Posted by 2K6E55
You seem to be very knowledgeable regarding these CLS55 wheels. How do I fix this issue to prevent rubbing? (Raising it via Star? I dont want my bumper to fall off)...
You should do the compression test before anything else and then decide.
You certainly cannot increase an offset on the wheels: even if you could machine the mounting plate 10mm, your lug bolts seat will get too thin.
I had the option of putting these wheels on my car and decided against it because of the offset. A 275/30/19 tire might help, Ihave seen other guys with these wheels on the forum. Also, a little filing of the plastic bits will help. You might just shoe-horn it in! If all that fails, or you are not up to modifying body parts, start looking for a CLS350 or CLS500 owner who wants an upgrade to a CLS55-look. Sorry!
#32
I may be wrong, but I am almost certain that you will have a nice ,deep groove in your tyre wall by the time you park your car in your dacha..
Although I must say they look kinda cool hanging off the sidewall like that...
Loren
#35
I may be wrong, but I am almost certain that you will have a nice ,deep groove in your tyre wall by the time you park your car in your dacha...
or may I should first try ET35 or ET37...
My tuner ordered 8mm and 10mm adapters already...for ET35 and ET37...
Loren...
What is your offset ???
#37
Originally Posted by baldmike73
Unfortunately when you remove the front plate you are left with the 4 little holes the dealer put in the bumper when putting on the front plate. I hate it on mine and have removed the plate and am still looking for something to fill those holes so it doens't look so funky.
Nice wheels!!!!! I agree remove the front grill.
I had the same problem, i took it back to the dealer and started getting pissed cuz they did it without my consent...and they filled the holes and you can't even see where they used to be...hope that helps
#38
Here's a photo showing the exact place where the tire rubs the fender (this is 285 on a ET33, so ET28 will be another 5mm worse off!))
I also actually had the slightest rubbing on the very top of the fender lip but again not a sign of making or cutting on the tires but a bit of tire shine on the top most part of the lip.
I could cut down the plastic bumper lip and ever so slightly roll the fender and make it work but do I really want to do that?
So with that thought I passed up a set of un-used SL55 wheels that were such a deal at 1k with brand new P-Zero Rosso tires.
Honestly the car had less grip with those wheels and had a far worse ride than stock. Rosso's are stones compared to PS'2 and the grip was terrible. I now what to put PS'2 on my SL and see how it feels!
SO to M5 Russ yes you will risk rubbing on a 285 and the off-set will make or brake the deal... along with tire brand.
#39
#40
Update...
As much as I love these wheels, I think I will need to part with them because they do RUB! Since I did the compression test as Rafal suggested and my love of driving in Sport II will NOT allow me to keep these wheels.
Anyone out there interested in them?
Take a look at the newly painted grill... The OE did NOT turn out so good, I am having it redone.
#41
From: New York, Shanghai, Hongkong, Bangkok, Penang
honduh, bimmer, bEnz, ferrari and etc
is that the CL style grill painted black?
#43
Originally Posted by JamE55
Looks good and clean. Take out the grille though. It doesn't look right for an E55.
#44
This grill looks so much better...too bad about the wheels...
Rafal...so you say P Zero is not good...Cause my 2nd option was P Zero NERO or Nero is OK...
Does PS2 come in 245/35 front and 275/30 rears ???
#45
Yes, PS2 does come in 245/35 & 275/30.
Too bad the wheels rub because they look great on the car. But like James said, the grille seems a bit out of place.
