lost of power...
hi everyone.. i need some help please
i got a 2003 E55 stage 3 kleemann which i supose have about 620bhp.. i have taken it for a dyno test test, i got a depressing 430bhp in the rear wheels only.. i think i got lots of loses.. one more thing when i hit the peddle a little, i can hear a whistle its like a turbo blow valve.. is that normal or could that be the problem.. please try to help me
thanks alot..
There are lots of possible things that could cause your problems and from the top of my head some that I remember reading about (or the major one) is temperature causing the supercharger to disengage.
Another issue that Marcus brought up was the water pump.
Search the forums for posts by Marcus, vrus, Grumpy and a slew of other members and I bet you'll find the answer you're looking for.
BTW - welcome to MBWorld.org, got any pictures of your ride?
check if you can locate shiny headers at least.
Every E55, SL55, etc that I have been in has a "squeak" when you first get into the gas hard.. alot like a belt slipping on the supercharger pulley ( Type sound )
Steve
1-Water pump problems are almost commonplace on the 55's. When it acts up, Kompressor shuts right down to protect.
2-Heatsoak. K3 makes monster heat and when gets over a certain temp, ECU is gonna shut that blower down.
Welcome to modding...now if you go to the stealer, you will be treated like a criminal. Sometimes they can be cool though.....sometimes just big fat jerks. Usually they can spot it pretty fast. I would play dumb..."Golly, the man who sold me the car said he had some engine upgrades...but I didn't understand what he meant. "
Good luck and keep us updated.
Second thing is, if you are hearing a whistling sound like air escaping, then get a friend to sit in the car and rev the engine. Check all the hoses from the air boxes to the throttle body and also check the connection from the intake manifolds down to the supercharger's intercooler output. There are 2 silicon hose connectors that connect the cast iron intake manifolds to the intercooler output. Make sure those are on tight and that there is no tears in them.
If you have an air leak you are losing boost and that would account for the drop in power. For comparison, my car did 411rwhp stock and 442rwhp with just headers on the car (no ECU and no pullies).
On a Dynojet my K2 is showing 430 rwhp corrected, and I'm still trying to find my missing hp.
Mustang is one of the brands/makers of a Dynamometer. There are a bunch of different manufacturers of Dynos.
If you can, post your Dyno sheet. I'm not the guy to evaluate it, but someone like vrus is more qualified. Maybe he can comment.
The car is a beast.........just wish i had more hp,but i am working on it.
Give Corey at Kleemann a call,he will burn you a new chip,and help you in any way he can.He is a wizard on the E55.
You need to look also at you s/c belt to see if its slipping.......that could be the power robbing culprit..........b/c if the belt is slipping the car will rchen its self ,which will result in a lost of top end hp.
