Cold Start
Old Apr 25, 2006 | 08:46 PM
RJC's Avatar
RJC
Various
Question Cold Start
I've noticed when the car sits overnight during part of the cold start cycle the engine idle gets a bit "lumpy" which kind of shakes the car a bit every few seconds or so then after a minute or two it idles very smoothly; is this normal with the 55?
Old Apr 25, 2006 | 08:52 PM
hydeaway's Avatar
996TT
mine does the same thing - even before and after the K2 upgrade....
Old Apr 25, 2006 | 08:59 PM
RJC's Avatar
RJC
Various
Thanks! I feel alot better Is that a long or short hair Jack Russell in your avatar?
Old Apr 25, 2006 | 09:08 PM
ENDSMTG's Avatar
'08 S65, '04 Range Rover(The House), '06 Lexus GS 300(Wifey's), '02 Sea Ray 360 Sundancer
Diddo, mine also has a rough idle until warm-up!
Old Apr 25, 2006 | 09:18 PM
2K6E55's Avatar
AMGs
Mine does the same thing...
Old Apr 25, 2006 | 10:17 PM
AKxSpyO's Avatar
2005 Flint Grey E55
Same with my car, so i let it idle until the temperature guage reaches a couple bars under the half line bar.
Old Apr 25, 2006 | 11:19 PM
Grumpy666's Avatar
You can thank CARB for your cold-start symptoms. Cold engines are set to run lean until the cat fires off. A lean-running engine will idle roughly.
Old Apr 25, 2006 | 11:38 PM
JamE55's Avatar
Out Of Control!
Mine does the same thing and never smooths out. But that's normal considering i'm running a set of K cams.
Old Apr 25, 2006 | 11:57 PM
RJC's Avatar
RJC
Various
Thanks for all the feedback.
The reason I noticed this is I always let my cars idle down after a cold start before driving off; I've just never had one shake it up like this before. I also haven't heard of this problem with 2006 500's, 350's etc; maybe it's a 55 thing? If it is a 55 thing should n't MB provide a flash update for the ECU. Aren't cars allowed to run richer during the cold start cycle?
