Need advice on wheel/tire sizes & offsets
2002 E55
Thinking about 19X8.5 & 19X10 rear on my 02 E55...Will those sizes work? What offset & tire size should I be looking at.
2017 S63 Coupe Iridium Silver
Rafal is right...You lucky !!! Learn my mistake...
I beleive ET30 front and ET33 rears is a good combo...
285/30 will fit with ET 35 if not lowered, if lowered only ET38 but then IMHO you loose some apperence as wheels would be more inside...
My specs:
Work Wheels
19x8.5 ET28 (245/35/19)
19x10 ET 36 (275/30/19)
here's a link to pics if you'd like to see:
https://mbworld.org/forums/showthrea...ght=work+vs-xx
Hope this helps
Work Wheels
Hope this helps
Originally Posted by OzE55
Very nice.
You must have lowered the E500.
Out Of Control!
Originally Posted by Rafal
I agree, great looking car! tbone gave me the idea for washer lowering, so I guess his car is done the same way!
Rafal: Thanks as well. I did lower my car, not via washer method though. I changed the links in the front and moved the sensor in the rear.
Originally Posted by JamE55
Depending on the brand and make of the wheels you'll be getting, those size should be ok. Or you can also run 19x9F and 19x10R. At least that's what i'm running on mine. 245/35/19F & 275/30/19R.
Out Of Control!
Originally Posted by tbone
Neal @Eurotech also told me I could run a rear 10.5" on my E500 (and I don't have pre-rolled fenders). This is an HRE rim, which will give you a 4" lip.
M5 RUS and Tbone don't have W210's so don't assume those specs will work. The front is very difficult and most of the offsets are for cars outside the US that us 235/45/18 up front. If you are going to use 245 width tires and a 8.5 inch rim up front you must use et25 thru et28. Do not use any offset that pushes the rim inward more than 4mm.
I put on an aftermarket rim that push the wheel inward 4mm and it rubbed with some tires. I went from the OEM 18x8 et31 to 18x8.0 et35 and that 4mm changed using a 245 tire is the max with no room inside to go further in.
Out Of Control!
Originally Posted by E55 KEV
Jam, we go way back on this issue - so don't be confusing guys with your setup. You don't have OEM brakes up front so your offset will not apply to the cars with OEM setup.
OZ: Thanks for the compliment
Well done!
