Service Campaign
Recall relay air injection pump and secondary air injection pump
Diagonosis assitance system, disconnect & connect
Engine Control Unit Software, Install
Control Unit (W/ DAS CON.) Code
Battery Charger D/C
Fault Memory (W/ DAS CON) Read out and Erase
Replaced alternator voltage regulator
all of course no charge..
The beast runs amazing now. I thought it ran great before but now it revs faster and smoother and the engine sounds incredible. Time to go to Sac. and make a run.
The work that you describe is more than the items that were listed in the service campaign letter that I received.
Happy Motoring in your MBs
Ted
