*** 80mm AMG Throttle Body ***
#702
1 Post
2006 Weistec 3.0L SC'd C55, 2006 MaxPsi PT6466 Turbo'd M3, 2019 Maserati GTS , 2020Alfa Quadrifoglio
I need one!
How much and when can I get one? Will it work on a C55? I will paypal you if the price is right and it will fit a C55.
I am also interested in the $260 smaller underdrive pully for a C55? What about a SL55 splitter for a C55. Will pay for that as well?
#704
kit for c240
I've seen the 80mm intakes is this availible for a c240 and I plan on getting the ud pulleys and a ecu upgrade any info on the c240?
meant to ask if its availible for the c240
Absolutely! I agree that the ECU can compensate enough in stock form because the cars come out of the factory on the rich side. Leaning it out and adding the extra airflow is a great benefit..
Mikey, Mikey... You didn't even take it out of the box... Now I'm offended... You don't even want to take a peak and see what all my hard work looks like?? LOL... Go make some phone calls and get that bad boy installed..
You got my cell # right? Give it to your installer and if he has any questions, tell him to give me a shout.
#707
1.This thread is very old
2.The user you are contacting has a title under his name that means he can not post back!
3. Parts (80mm TB and inlets) are available through AMG them selves, you just need to dig through posts to find the part numbers.
best of luck
#708
NEW TO FORUM
thanks still getting used to this forum thing I usally just direct my question in a text to my buddy, but hes been stressed at work so I have to look elsewhere latly for info
thanks again for your help
3 things you need to know
best of luck
best of luck
#709
i tried 78mm throttle body on mine and my car wouldn’t idle and kept throwing code p2004 IMRC , put the 74mm stock one back on and it’s normal now , does a larger throttle body require tuning ??
#711
my car is a w210 i only see one connector for my throttle body , i put another stock throttle body back on and it’s runs great
