W211 E55 Kompressor cut out problems
Old May 25, 2006 | 12:41 AM
BlackBear's Avatar
2014 Mercedes E63
I have a 2004 E55 with 22K mls.
I have a problem with the Kompressor. If I accelerrate from 70 to 130 it cuts out just before 130.
The first time it happened I did three runs from about 60 to 110. When I wanted to do the forth one I had almost no power.
Now I can't even do two runs without this problem.
This happens at 60 to 80 degrees. I don't think even 80 degree weather should be a problem.
What could be the cause?
Does the dealer know how to fix it? Do I need a new Kompressor or should I insist on a new one?
Thank you,
Oliver
Old May 25, 2006 | 12:50 AM
aintME's Avatar
Mercedes-Benz
This has happened to many of us. Search this forum for some of the past threads.
Old May 25, 2006 | 09:12 AM
enzom's Avatar
2005 E55
The short answer is that it is probably an intercooler water pump failure.
Old May 25, 2006 | 09:42 AM
Dogshine's Avatar
CLS55
its being discussed right now in this thread regarding the intercooler pump....
https://mbworld.org/forums/w211-amg/149289-has-anyone-heard.html
