Dynoed my E55 today
'06 E55 Black/Charcoal
Dynoed my E55 today
Dynoed my 55 today and made 402 whp and 465 wtq on a notoriously conservative/low dyno. Did 2 runs completely stock, and 2 runs with the green filters in. Green filters only added 1whp. Relatively cheap hp/per dollar ratio.
Here is the link to my dyno sheet and video's on the dyno. I am not e-literate so my buddy Jared hosted them for me.
http://naplesracing.com/thread.php?p...501#post156501
The guy that runs the Dyno builds 6 sec. Mustangs and Chevy's, he was quite impressed and thinks it has at least 20 more whp if he could lean it out. I am still debating what tuning company to go with and to be honest Activie Autowerke's is starting to look good, but I will probably go Kleeman or Evosport. I can get a great deal on Renntech through a friend, but they seem too conservative. I have some time to figure it out. I don't want to mod it until I hit 4k on the odo. cause I want the piston rings to seat properly.
NICE........ i got a 04 E55 stage 3 kleemann i just dynoed it i got 470whp...... but i got the same problem like yours which is the mixture... i spoke to someone from kleemann they said they cant do anything for that, it goes rich cause of the heat, it protects the engine.... please tell me if there is a way to make it leaner..
Originally Posted by bsimonson
IIRC manual trans is about 15%; AT is more.
20+ to list......
Originally Posted by korveine
just wondering, what if ones does the ECU reset trick and then run on the dyno again... would that increase the numbers any?
The absolute best automatics will not be better than 19-20% (typically autos are 20-21%. The best front engine rear drive manual transmission cars wont be better than 17%. And the best rear transaxle cars have 15% drivetrain loss. 19-20% are the numbers you should be using.
'11/E63-Former car: '05 RT4 E55, Sprintbooster, Phenolic Spacers, RT IC /Secondary HE & BMC Filters
any reason that RENNtech on website for dynosheets recommends 1.23 (assume 23% drive-train loss?) multipiler for rear wheel conversion to crank. can see if independent dealer selling the mods would maybe market this way to entice buyer , but for RENN to post on site seems interesting. any idea why that conversion factor? thanks.
Former Vendor of MBWorld
W211 E55
Actually, that works out to about 18.5%.
400 rwhp TIMES 1.23 equals 492 crank hp.
400 rwhp DIVIDED by .815 equals ~491 crank hp
I hope this helps.
I hope this helps.
23% is too generous, tahts just boosting their numbers to make them look better. AMG autos are the best out there so they are probably right around 20%. sport autos are around 21%, the absolute worst autos are 23-25%. if you use 20% it will be closest estimate to your real cran k numbers. 1.23 is too high though thats for sure. Its DEFINITELY not the 15% that alot of these guys on the E55 forum have been claiming, those numbers are WAAAY off. hope that helps.
W211 E55
