Alert!! Hold On To Your Stock Ecu
Who knows if mercedes decides to extend this to other vehicles. I already know that the 2006 SLK55s have a bit different programming than the 2005s. To be honest Ted, while I don't speak for Renntech, I would be highly surprised if Renntech was willing to reprogram a Kleemann car. I'd expect that Kleemann would also not be willing to reprogram a Renntech car. But who knows ... you are a customer that I"m sure Renntech would love to have. If not now than for the future.
Good luck to everyone with this issue I hope it gets resolved ASAP.
...........I am not an engineering and did not sleep at the Holiday Inn last night. So the above information is not intended to sbstitute for the the informtion you get from mercedes regarding the safety of your car.
Ted
In my case, being in CA, we originally decided to put race cats in instead of removing the primary set completely. So, after the recall, mine should be just fine since the high flow race cats should do the job and not trigger anything. Those of you with working setups post recall / reflash... do you by chance have working primary race cats in your K2 setup?
Normally those are removed in the K2 setup unless you're in a smog sensitive place like CA, in which case Cory recommends the race cats. I suppose you could always retrofit and put them back in if you wanted...
Cory also found another way around it I'm not fully up on, but it involves doing the reflash while its in the car (Rock / Dave, you know what I'm talking about... explain it if you want... I'm gray on it).
So, I'm doing the recall today, then sending my ecu out, then I'll put it back in and let you all know.
Loren
Also we don’t have any power loss, we were well prepared for this in advance since we knew it was coming for almost a year."
Guess I don't have to worry about it. Nor should the other Renntech owners ...
Not sure how a Renntech ECU would run on a K2 car and Vice Versa, but the last thing we need is a Renntech Klee battle.
Let's focus on the real enemy...mother f'in Benz for trying to keep us from modding.
Benz is gonna learn real quick why we love these cars....hopefully not the hard way (sales plummeting)
I drive this car for the luxury AND PERFORMANCE. Get a clue Benz...cut this ***** out before this gets out of hand.
Sorry....just pi$$ed right now. I need a kill....be right back.
My a/f on top is running 10:1,but the car does not feel flat on top.
I would be more concerned if I had a stock ECU and MB was about to re-flash it. I hope we can get some pre and post dyno as well as track numbers from people that are stock.
Loren
.............lets not confuse each other. I too have been speaking with Cory. The problem is that very few people have actually dynoed their car after the recall. Everyone that has dynoed their car made less power except for one CLS55.
.........The consensus as I understood it was that the cars drove crapy after recall and drove much better after Kleemann re-flashed the ECU. So from that standpoint, don't worry.
..........the other problem is that actual dyno figures before and after recall. And the results are as I stated above.
.........If there isn't a problem why is Kleemann Denmark working on a solotion for a non-problem?
...........The G55 program is a whole other issue. My car is not even driveable now. I can't go past third gear............the car just stalls as the engine pulls timming.
..............lastly, why are you even doing the recall? To avoid a check engine light triggered by the secondary injection pump? Makes no sense. Everyone that has had a check engine light has been from the O2 sensor problem and the check engine light comes right back on as you drive your car out of the dealership after the recall. No check engine lighs from the so called secondary air injection pump have so far been reported by anyone.
............Finally even if you decide that the recall work is neccessary, there is DEFINITELY no reason to reflash your ECU in order to fix the secondary air injection pump relay.
............If you insist on doing the recall, I will suggest you make sure they don't mess with your ECU.
Ted
Ted
1) To keep MB and my service advisors from getting all uptight about these mandatory things they're ordered to do and
2) Because the new K2 program specifically requires the recall / flash for it to work. Cory can't provide the new "scary fast" program if the recall / flash isn't done. As MB changes these programs, Kleeman adjusts future ones to match that upgrade path. With all the moving around that happened, the new K2 program won't run on a non flashed ecu...
Loren
PS. Irony: While doing the recall work today, they discovered a portion of my SBC system was failing and needs to be replaced... so its in the shop for an additional day. By friday I should have the ECU back from Cory and will be able to accurately gauge this whole thing and vote in the other thread properly...
ie how do we tell if we have it, when did they start using it? Is it only US guys that have experienced deteriorating performance? or is it worldwide?
