K2 being "tweaked" - 457RWHp and climbing
If you ever get a chance, would you mind throwing your car on another dyno that is not the Chris at C2 dyno just for kicks.
It just seems like every post that we get from people going to Chris at C2 is unusually high. This would be the 3rd or 4th (largest horsepower he has ever seen) post on the forum. C2 has a flawless record and his work is second only to the masters in Co Springs.
I was just curious as to what she would make on a separate independent dyno.
Believe me, I want you to have 490 rwhp, all of us want you to have 490rwhp....and if she pulls it on another dyno, I will eat my humble pie with just a touch a salt.
Here are a list of Dynojet Dynos in the FL area you can try if you need the info.
You don't have to prove anything to a schmoo like me I know, I just want to make sure that you have the most accurate information on what your car is putting down. If she rolls close to 490 on another dyno, you got yourself the highest hp K2 in America beside the God of Hellfire Gid_E_Up
Best of luck either way Ken....SOUNDS AWESOME!!
There are people on here with 500rwhp and running 11.9. There's me with 460rwph who ran 11.65 and others even faster.
I spend alot of time on the dyno because I use it to validate any changes I make to the car.. It tells me if something I bought is doing what it is supposed to or not. The number itself is irrelevant because on a day-to-day basis, and dyno-to-dyno basis, those numbers change quite a bit. What is important to me is the differential #'s I get going from one change to another.
Only way to know for sure if one car is stronger than another is to put them on the same dyno on the same day or line them up and run them down the 1/4 and see which one is in front.
All that being said, C2 is making some pretty bold statements... and, in my opinion, passing along some pretty high expectations to it's current customer (Ken). But, everyone knows that dyno #'s are a marketing tool, and that is how vendors & installers make their sales.
BTW, on your before & after dyno pulls that C2 did/is doing, make sure you get the CORRECTED #'s for both.
As far as my 80mm TB project goes.. It is at the dealer being installed as we speak along with revised pullies and 2006 supercharger clutch pack.. Should have updated dyno numbers by week's end.
on the street that I'm not real concerned with what the DYNO says. I'm simply looking at the Dyno #'s to insure there is legitimate merit to the work being done and proper tuning with each mod. Chris may lean out the A/F....give me only 10 more HP, and I'll still be HAPPY with the K2mods!
The real proof will be the performance #'s in the 1/4 and that I'll know in the next few weeks......BTW-If I can get it done "conveniently" - I'll also get a local dyno done on the car once all my mods are done. (still think'n serious about larger TB)
There is a guy in Stuart FL. 40 miles up the road from WPB. Whom I use from my Dyno testing . 3 pulls for $75.00 He just had it calibrated a couple of weeks ago
Bruce MacDonald / MacDonald Motor sports 772-283-3939. Let him know I sent you. I have a CLK 5.5 AMG
I've done 33 pull's at his place ___PTE___ Take care
I have a place 200 yds from my "plant"/business that has a chassis dyno.
The place is "Japtrix" and is very reputable with the "riceburners" as a few of my employees frequent them. Anyhow-a second dyno is not an issue.
Will do it when the time's apprpriate and convenient.
