Carlsson pulley?
Old 07-15-2006, 12:45 PM
Vadim @ FD's Avatar
S600TT, R350
The answers:
Vadim would you guys consider selling the extra idler pulley seperate?
That will be up to evosport.
Posting the video would be very useful to all. Please.
Since I no longer work at evosport, I do not have access to it.
If I purchase the Evosport-evolution 1 power package today, is the set up you described above what I will get?
Correct.
Old 07-17-2006, 10:25 AM
E55 RUSS's Avatar
E55K
So Evosport are the best pullies on the market rightnow ???
Do people with Kleemann pulllies have same problem ???
Rflow you have this problem with ASP pullies as well ???
Old 07-17-2006, 11:10 AM
E55 RUSS's Avatar
E55K
Did this probler with Kompressor tensioner just occurred, how come no one solved this problems yet ???
If I get larget pully like ASP, mean I will definately need to make amke some like Finn has ???
Old 07-17-2006, 05:59 PM
Finny's Avatar
03 E55 AMG
Thumbs up This is what I'm talkin about!
We all need this setup... See pics... Also check out this link http://www.billetflow.com/IdlerBracket.htm Unless someone else comes up with a similar product, I'll try and mimic below using the same pullys.
Blue, Black, Silver or Red guys? ...Mmmmmm Decisions?
I wonder if the company would make up a custom batch for a group order?
So what do ya all think?
Carlsson pulley?-ford-blues-pulley.jpgCarlsson pulley?-grooved-pulley03.jpgCarlsson pulley?-hard-sc-pulleys.jpg
Old 07-17-2006, 06:50 PM
GTA23109a's Avatar
04 E55
You can get thos flat (backside) idlers from GM parts all day long. I had like 3 of them laying on a workbench until I threw them away a few months ago. That's basically the same idea I plan to try implementing. Get more belt wrap and stop that long-run belt oscilation.
Old 07-18-2006, 05:48 AM
E55 RUSS's Avatar
E55K
Hello Finn...
What Idler Bracket do I need to order from them ???
Old 07-18-2006, 10:17 AM
  #32
Finny's Avatar
03 E55 AMG
Exclamation We need a Bracket...
Originally Posted by M5 RUS
Hello Finny...
I don't believe one is available for mercs.
They may customize one if there were enough orders...
Old 07-18-2006, 11:30 AM
  #33
E55 RUSS's Avatar
E55K
Which one you have then ???
Did Simon make it for you ???
Some tell ME something bad about ASP pullies ??? and why I shouldnt get it
Old 07-18-2006, 01:41 PM
  #34
Finny's Avatar
03 E55 AMG
Some tell ME something bad about ASP pulleys ??? and why I shouldn't get it
Unfortunately I don't have a mounting bracket yet, as I said before... If a commercial option isn't available, I'll make it myself.
I'm assuming in your third question that your asking about an ASP pulley setup?... I don't know anything about that particular brand, but most obviously would suffer the same problems as the other brands.
Are you pulley-Less at the moment? Apparently the new EVO version has been corrected but haven't seen any specs or photos to date.
Maybe you should investigate this option.
Old 07-20-2006, 12:22 PM
  #35
E55 RUSS's Avatar
E55K
Finn...
What about Simons pullies are they simular to ASP ones, just re=worked MB ones with bigger diameter...
You have some probs with belt slipping wit Simons pullies ???
I dont know which pullies to get ???
Old 07-20-2006, 12:55 PM
  #36
Finny's Avatar
03 E55 AMG
Exclamation Rap
Finn...
What about Simons pulleys are they similar to ASP ones, just re=worked MB ones with bigger diameter...
Yes
You have some probs with belt slipping with Simons pulleys ???
I don't know which pulleys to get ???
Get the EVO Mk II set only if the slip problem has been corrected. You will need to investigate further. Let me know what you find out.
Anyway, it's not the big pulley that slips but the small one on the supercharger. Thats why we need to wrap the pulley up.
See Photos above.
Cheers.
Old 07-21-2006, 11:40 AM
  #37
E55 RUSS's Avatar
E55K
So with ASP pullies I am most likely to have slip belt issues ???
Send one of you custom pieces to ME...and if you speak to Simon, ask them about my ECU upgrade, he still didnt reply (:...
I also need some instructions and tips on how to prepare and install thier headers !!!
Thanks man
Quick Reply: Carlsson pulley?
